Mirror
Old Aug 16, 2009 | 02:24 AM
SportCustomWalt's Avatar
SportCustomWalt
Mirror
I have a 96 Ranger that has had the mirror smashed out. I looked up under where it swiveled and there is a cover. I removed it and there is a screw that i quess tightens it. I was wanting to just take it off there instead of removing the door panel and undoing the 3 bolts. Can this come apart at the swivel? It would make it alot easier.
Old Aug 16, 2009 | 09:46 AM
Bear River's Avatar
Bear River
Former ******
To answer you simply, no, you cannot take it apart there. The fitting there is designed for the swivel and not for removal. If you take it apart there, you will most likely end up with a mirror that will not stay where you set it. When you buy new mirrors, they come as the whole thing. If you get on in a yard, you would also get the whole thing. Its not that hard to remove the door panel, heck, while you are at it you should lube the window track and door linkage with some white lithium grease.
Old Aug 16, 2009 | 10:04 AM
SportCustomWalt
It has a 6 pt allen or a cross tip head and it goes up through the swivel and tightens in a flat square washer with female threads. It's not that i don't want to remove the panel i was hopeing that it would be less time consumeing.
Old Aug 17, 2009 | 12:52 PM
1Aauto's Avatar
1Aauto
Former Vendor
HI Sport,
Wasn't sure if you needed a replacement mirror.Here's a link to them for your application on our site,if you would like to check on pricing.
Ford Ranger Mirrors
Old Aug 17, 2009 | 02:14 PM
SportCustomWalt
Mirror
Originally Posted by 1ATony
HI Sport,
Ford Ranger Mirrors
Hello A1Tony,
I just purchased a 1AMRE0014 Driver side mirror. I really miss that mirror so i'm glad you posted where to purchase one and really good price and free shipping also. So thanks again and i'll be waitting for it to arrive.
Old Aug 17, 2009 | 02:26 PM
1Aauto's Avatar
1Aauto
Former Vendor
Originally Posted by SportCustomWalt
Hello A1Tony,
Anytime
