lowered coils
Old Aug 15, 2009 | 12:16 AM
derekfriesen's Avatar
derekfriesen
lowered coils
hey does anyone out there have a set of lowered coils that they would like to get rid of? i am looking for a set for my 65 f-100
Old Aug 15, 2009 | 08:02 AM
ddavidv's Avatar
ddavidv
No such thing...you can't put lowered springs into a Twin I Beam truck. It will dramatically alter the camber. To lower the front you need to use dropped I-beams.
Old Aug 15, 2009 | 10:43 AM
derekfriesen
i have drop i beams and am looking for a little lower . so lowered coils will do the trick
Old Aug 15, 2009 | 10:45 AM
derekfriesen
and to correct you ! yes there are drop coils avlible! (blueovalparts.com)
Old Aug 15, 2009 | 01:30 PM
jared66's Avatar
jared66
LMC sold them in the past, however i was looking at there most recent catalog it looks like they no longer sell them. I think what ddavidv was refering to is that people dont always think its a good idea to lower a I beam truck with this method because of alignment problems. It can be corrected by having your i beams bent, but you have to find a shop that knows how to do this. Some people will tell you this is a bad idea because its a saftey issue. However i do know they use this method with semitrucks. I'm not sure if it is a good idea or not you will have to decide for your self.
Old Aug 16, 2009 | 06:53 AM
ddavidv's Avatar
ddavidv
The OP didn't specify he already had dropped beams. That makes a difference, of course.
There are lots of ways to go about dropping the front of these trucks (a concept I don't understand, personally, but that's me...) but dropped beams are really the best. The I Beams can be bent, true, but it's a rare skill to find and probably not much cheaper than simply buying beams.
Old Aug 16, 2009 | 02:56 PM
garbz2's Avatar
garbz2
And aftermarket beams in no way can be reset to correct camber. only forged factory units can be hydraulically bent to correct it by a large truck shop.
And just because some one sell drop coils does not mean it is right or correct. It is still up to you to correct the deficiencies in camber.
Garbz
Old Aug 16, 2009 | 04:32 PM
drof46's Avatar
drof46
If you have drop beams already, I would adjust my tire size. Summit or others show the tires size and overall diameter. I currently have some 29 inch diameter tires and was thinking of going with some 25 inch diameter tires. That would net me 2 more inches in the front. Took a drive today and hit 2800 RPM at 55mph. No way I will decrease tire size in the rear.
