Sponsored by: Real Truck
brake bias issue
Old Aug 14, 2009 | 08:54 PM
jeffdoerr's Avatar
jeffdoerr
brake bias issue
Got 2 trucks doing the same thing. One is a 99 and the other a 2000. Seems like only the front brakes work. All parts are good, pins free, calipers working, etc. Just seems to be about 90% on front, 10% on rears. My 2006, by comparrison, will stop on a dime and you can feel the rear brakes working like they should, with and without the trailer behind.
Old Aug 14, 2009 | 09:05 PM
Mustang6147's Avatar
Mustang6147
Stuck proportioning valve, is what it sounds like to me. Some people say you can slowly drive, and jam on the brakes a couple times, and it will correct the ratio... I have never tried it, nor needed to.
It is also said this process will cure squeeking brakes, if they are good.
Old Aug 14, 2009 | 09:29 PM
jeffdoerr's Avatar
jeffdoerr
you are correct. Sounds like a stuck proportioning valve. I was not aware these trucks had one. I was not able to locate one on the 2000, the lines seem to go direct to the abs unit. Probly quite tolerable if this was a grocery getter, but it gets old going 200-300 miles every day with a loaded trailer. My front rims are black with brake dust and my rotors are getting bad (they are only a few months old, right from the dealer).
Old Dec 6, 2015 | 09:35 PM
99f350sd's Avatar
99f350sd
Old thread but my 99 just uses the fronts also...
Al Lovell
Large Truck
Feb 23, 2017 11:31 PM
dwstenersen
Jan 9, 2017 01:46 PM
Sykesville
19
Oct 2, 2016 10:09 AM
Bakerr
Apr 2, 2016 08:46 PM
rookiemistake
Dec 9, 2015 10:01 AM
