4R70W vs. The E4OD
Old Aug 14, 2009 | 05:41 PM
rcn's Avatar
rcn
4R70W vs. The E4OD
Whats the better transmission? My f150 has the 4R70W, but it seems like many other owners have E40D. Why were there two different
transmisions offered?
Also, which do you think is the better transmision?
Old Aug 14, 2009 | 05:48 PM
Sportruk's Avatar
Sportruk
E4OD hands down. The 4R70W was used behind the smaller engines, while the E4OD was behind the 351, 460 and deisel.
Old Aug 14, 2009 | 05:50 PM
6CylBill's Avatar
6CylBill
Don't know much about the other transmission but I find my E4OD to be sloppy, power robbing, doesn't tolerate heat well and is very sluggish at going into gear, especially cold. However my transmission is still doing it's job - so I can't compain too much can I?
I'm not the original owner so I don't know all the work my tranny may have had in the past.
Old Aug 14, 2009 | 06:08 PM
Old93junk's Avatar
Old93junk
E40D........without a doubt, for the heavy duty applications.........With a LARGE aftermarket trans. cooler, they will give no troubles........Failures with most any auto trans are heat related.
Old Aug 14, 2009 | 07:33 PM
cjg1999's Avatar
cjg1999
my 94 super cab is a 302 "smaller engine" E4OD. not sure if they ever put it behind a 4.9 6 cyl. E4OD is better though, its a C6 with OD.
Old Aug 14, 2009 | 08:08 PM
Sportruk's Avatar
Sportruk
Yes, there was several different combos they put together in the Pre'97s and I have never been able to figure them out.
Old Aug 14, 2009 | 08:18 PM
jroehl's Avatar
jroehl
I don't know about trucks, but I have a friend with a mid-90's E150 that has a 4.9L/E4OD combo.
There are also a couple versions of the E4OD from what I can tell. For one, there are two different bellhousing patterns--300/302/351 and 460/diesel. With the different bellhousing also comes different torque converters, too, I think. The small V8s and I6 get a lighter duty T/C than the big V8/diesel. I think the lock-up clutch is 3 plates vs. 1 plate or something like that.
Jason
Old Aug 14, 2009 | 10:12 PM
Conanski's Avatar
Conanski
All automatic trannys will benefit from a shift kit and some much more than others, these are mass produced components and tolerances vary a lot.
Old Aug 14, 2009 | 10:19 PM
dwrestle's Avatar
dwrestle
The E40D is a very tough transmission I would trust it over any GM transmission TH400 included. It's not good for performance in stock form though.
Old Aug 15, 2009 | 08:00 AM
TexasGuy001's Avatar
TexasGuy001
The E40D is definitely the heavier duty transmission.
I have the 4R70W in my truck. I will say that in a F150 with a 302 I would rather have my 4R70W. It shifts much better and more predictable than the E40D. My 4R70W has over 270k miles on it.
My previous truck that I had back in the late 90's was a 95 F150 4.9 E40D. It shifted just like 6CylBill describes.
It depends what the truck is used for, as to which is better.
While we are talking about transmissions, what makes a 4R70W different than an AODE from a Mustang or Crown Vic?
Old Aug 15, 2009 | 08:59 AM
Conanski's Avatar
Conanski
They're essentially the same thing just different steps of the evolution from the all mechanical AOD to a tranny with some electronic controls(AODE) to one with a deeper first gear and various internal upgrades for higher capacity(4R70W).
Old Aug 15, 2009 | 09:56 AM
rcn's Avatar
rcn
I think its wiered that Bills has the E4OD, and yet I have the 5.0 and have the 4R70W... especially because I have bigger engine with more output... My truck has 102,000 right now and seems to run perfectly especially after I changed the plugs, wires, and cap... The last owner never changed the plugs, so they were the original plugs from the factory
The transmission seems fine to me... no problems whatsoever...
Old Aug 15, 2009 | 10:01 AM
lew52's Avatar
lew52
You have the tow pac so your 4R70W should last a long time because of the trans cooler being on there since new . A shift kit will help them alot to ... Lew
Old Aug 15, 2009 | 10:10 AM
Jason Lewis's Avatar
Jason Lewis
I Love my 4R70W 135,000 miles i do a trany service every 14,000 fluid filter, My truck also came with a trany cooler No problmes yet "Not on wood"
Old Aug 15, 2009 | 03:26 PM
6CylBill's Avatar
6CylBill
Your engine isn't bigger.
I think all mid 90's have the E4?
