truck wont start
Old Aug 14, 2009 | 04:57 PM
Jesse Zimmerman's Avatar
Jesse Zimmerman
truck wont start
I have a 78 f150 with a 351 and the f***** thing wont start. so far i have bought a new starter and a solenoid and batery cables and i cant get it to do anyting at all, any help greatly appreciated
thanks jz
Old Aug 14, 2009 | 10:09 PM
amish77's Avatar
amish77
so assuming all those parts are good and that the battery is good I'd say throw a wrench on the crank and make sure it's not jammed up for some odd reason. Also you can try getting some jumper cables and running one directly from the starter to the hot lead on the battery. If that doesn't work then the battery is definitely dead. Lemmie know what you come up with.
Old Aug 14, 2009 | 10:15 PM
hp246's Avatar
hp246
Were there any symptoms before you had the starting issue?
Old Aug 14, 2009 | 10:39 PM
ps2crazy29's Avatar
ps2crazy29
5th Gear
Check your brainbox on the right hand side of fender if your looking at motor. I had a 78 that just quit on me one day. I replaced solenoid, starter, battery connections and battery. I ended up pulling the brain box off of a junkyard truck and put it in and it fired right up.
YoungDually
Mar 8, 2015 11:02 AM
dads550
25
Oct 1, 2012 12:07 PM
blwtide1
Sep 20, 2012 01:31 PM
cjfarm11
Aug 25, 2011 08:35 PM
wenglish
General Diesel Discussion
Jan 22, 2007 06:48 PM
