General Diesel Discussion
Wont Start
Old Jan 22, 2007 | 11:54 AM
wenglish's Avatar
wenglish
Wont Start
Have a 99 F-350 S/D 7.3 diesel. during the freez i had the heater plugged in, went to start it and it wont start, but will crank over, any suggestions............
Old Jan 22, 2007 | 02:22 PM
BowTieHatr's Avatar
BowTieHatr
check to make sure your glow plug relay is closing. do you have any smoke?
Old Jan 22, 2007 | 02:31 PM
wenglish's Avatar
wenglish
no smoke, just cranks but doesnt start..........
Old Jan 22, 2007 | 02:52 PM
BowTieHatr's Avatar
BowTieHatr
look at your tach and see if it comes up when you are spinning it over. also try to put a charger or a booster on it. i have seen a low voltage concern on a 73 where it would spin over like everythig was ok, but would not start due to batt voltage dropping below 9.5 volts.
Old Jan 22, 2007 | 03:08 PM
wenglish's Avatar
wenglish
No tack doesnt move at all
Old Jan 22, 2007 | 04:09 PM
wenglish's Avatar
wenglish
any diesel mechanics in NW side of SA
Old Jan 22, 2007 | 06:48 PM
BowTieHatr's Avatar
BowTieHatr
sounds like a cam sensor. i think you can get one as cheap as 60 to 80 bucks if you shop around. when the tach does not move, that is a tell tell sign of no signal from cam sensor.
Mamma Bear
25
Jun 9, 2012 05:52 PM
MustangGT221
Sep 10, 2002 11:55 PM
DrFord
Sep 14, 2001 06:57 PM
lee
Jan 29, 2001 08:34 PM
Phillip Guidry
Aug 20, 2000 08:31 PM
