I have a 1999 F-550, 7.3 power stroke diesel with a 6 speed standard trans. The engine won't start with the key. It turns over fine, but won't start. However, it will start easily when I catch it in gear. Does anyone have any ideas why it won't start with the key? Thanks, Ken
OTHER NO START OR HARD START ISSUES
When trying to diagnose hard start or no start issues a scan tool is needed to check and monitor the ICP (Injection Control Pressure), RPM (From the CMP) Vehicle Voltage during cranking and PW (Pulse Width) signal.
1. RPM, minimum 100 rpm cranking speed (When warm it should be over 180 rpm)
2. ICP, minimum required for starting 500 PSI if no rpm signal, ICP won’t go over 400 PSI
3. Voltage during cranking 7-10 volts minimum depending on year
4. Pulse Width; 0 ms means no sync, 1994-1997 .42 ms indicates
that PCM and IDM are in sync (on 99-03 it should be .60 ms) and the PCM is waiting on the ICP to reach the minimum of 500 PSI. When min. ICP is reached PW should change to 1-6 ms
5. If any of the above doesn’t meet the minimum specification, solve the problem as-per the appropriate Ford Diagnostic Manual.
Thanks for all of your suggestions, however, I put in 2 new batteries and it still won't start with key. It was suggested that the reservoir wasn't full when trying to start. We tried to fill it, but it seems to be going down as fast as I put it in. I can't see any oil leaking anywhere. Any thoughts? Thanks.
Does the oil drain back down into the oilpan? Check your dipstick. Make DAMN SURE you are not over filled... or you might just get to see one of those fancy viewing window upgrades in the side of your block.
I know it is draining into the oil pan and I know it's not over full. But how is it leaking and is there a way to fix it? Also, could this be the cause of the no start with a key?
