Sponsored by: Real Truck
Pulling to Right after brake change
Old Aug 21, 2009 | 02:30 PM
mikesmayhem's Avatar
mikesmayhem
bill64 good tip. That would definately help to see if it was a bad line. The fact that it pulled before the caliper change and now after the new caliper was installed, I would also lean towards thinking it was a brake line issue.
Old Aug 21, 2009 | 02:50 PM
Boss08v10's Avatar
Boss08v10
My or may not help but find any empty parking lot and back up at a pretty clip then blast the brakes once or twice. Seems sometimes jaring the system in reverse helps reset things.
Old Aug 21, 2009 | 07:35 PM
mykels's Avatar
mykels
I did napa rotors and LTS pads on my 03 f250 cc 5.4. It pulled to the left for a few hundred miles and cleared itself. Maybe contamination on the rotors or pads.
Old Aug 21, 2009 | 07:49 PM
EXv10's Avatar
EXv10
It sounds to me like it has nothing to do with the brakes. When you hit the brakes they are giving equal pressure so it is correcting whatever was causing the pull. Are your bearings tight? All suspension tight? Did they reasemble it right? Go back to where they did your brakes and have them inspect thier own work.
Old Aug 27, 2009 | 03:47 PM
tilelayher's Avatar
tilelayher
I'm not trying to thread jack, I have the opposite problem when I brake my truck pulls to the right and badly. Replaced both front and rear: calipers, pads and rotors. Still has the problem and the petal now vibrates badly when I brake suddenly. Help?!
Old Aug 27, 2009 | 03:50 PM
EXv10's Avatar
EXv10
The ball joints can do that easily. I don't know about the pulsing but it sounds like a rotor or ABS problem.
Old Aug 27, 2009 | 03:57 PM
scraprat's Avatar
scraprat
Top Answer: 5
jdross440,
Did get the problem figured out and fixed? Interested in the problem and the fix.
Old Sep 3, 2009 | 12:13 PM
jdross440's Avatar
jdross440
Pull
Yes. It was the front left tire. It was separating on the inside. Still had 90% tread left. This is the 3rd Kuhmo tire I've had fail. Right front first, then the right rear and now the the left front. I'll never buy this brand again.
simulatedjim
Aug 9, 2014 07:51 PM
swhoskins
1997 - 2003 F150
Jul 5, 2012 05:08 AM
halaferd
27
Nov 16, 2011 10:28 AM
mechelement
19
Feb 4, 2009 05:02 PM
Ed in Maine
Dec 19, 2007 10:19 PM
