Brakes
Old Nov 13, 2011 | 11:24 AM
halaferd's Avatar
halaferd
Brakes
I have a '91 f250 diesel 4x4 with a brake problem. after it sits a day or two the brakes have pressure but as soon as you start the motor the resistance in the peddle goes to nothing and the peddle hits the floor.
I have replaceineptly lines on the front, rebuilt and cleaned the calipers, 99% new fluid, and replaced the right rear wheel seal, and bled the system several times.
when I got the truck the brakes hung and would get tighter the longer you drove it. The po replaced the right front caliper, booster pump, and master cylinder.
Please help haha thank you
Old Nov 13, 2011 | 12:30 PM
farmert's Avatar
farmert
It sounds like a master cylinder to me even though it was changed. It wouldn't be the first time a bad one was found out of the box. Was it a rebuilt or a new one. For the price difference I go with new.
Old Nov 13, 2011 | 01:20 PM
Lazy K's Avatar
Lazy K
When you bled the brakes did you bleed the RABS module? It is bolted to the inside of the left side frame rail about level with where the driver sits. You bleed it just like a brake.
Old Nov 13, 2011 | 01:33 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
it could be the rabs valve that is bad to.
Old Nov 13, 2011 | 02:21 PM
halaferd's Avatar
halaferd
Ok. Would the RABs cause the pressure to build and inhibit the brakes from releasing also?
Old Nov 13, 2011 | 02:41 PM
starmilt's Avatar
starmilt
Usually if the brakes won't release, it is a caliper sticking, but i did change a master cyl once and the rod was too long. This let them roll until you hit the brakes and then it would hold a small bit of pressure.
It sounds to me like you need to adjust your rear brakes.
Old Nov 13, 2011 | 02:44 PM
'94IDITurbo7.3
i would check rear brake adjustment and check the length of you booster pushrod.
Old Nov 13, 2011 | 05:25 PM
halaferd's Avatar
halaferd
I adjusted the pushrods also a few weeks ago. It was about a half inch to far in. I will check the rear brakes also
Old Nov 13, 2011 | 05:31 PM
halaferd's Avatar
halaferd
I just don't understand why it keeps draining into the lines when it sits then when the vac pump kicks in it looses all pressure.
'94IDITurbo7.3
i meant the pushrod that is in the brake booster on the firewall that applies pressure to the master cylinder when you hit th brake pedal. that pushrod does not have 1/2" of travel.
Old Nov 13, 2011 | 05:33 PM
'94IDITurbo7.3
do you have a vac gaug hooked up? very usefull tool.
Old Nov 13, 2011 | 05:41 PM
starmilt's Avatar
starmilt
When you crank it, your power gets to it,and it is easier to push the pedal, any vehicle with power will drop the pedal some when you crank it. If you didn't adjust your rear brakes when you installed new pads on the front, it is not unusual for the pedal to go to the floor. Will it pump up and hold steady, if so your rear brakes need adjusting.
Old Nov 13, 2011 | 06:26 PM
halaferd's Avatar
halaferd
The pushrod from the booster is the Oneida adjusted to specs(may have exaggerated on the 1/2")
And I havent adjusted the left rear pads yet but the right is correct.
When the truck starts the peddle goes about 3/4's the length of its travel. Then, it does not pump up any. It may have a tiny bit at the very end, just enough to slow the truck at 10mph, but NO more.
Could it just be there's still air in the system?
Old Nov 13, 2011 | 06:48 PM
'94IDITurbo7.3
so with the engine running there is no resistance in the brake pedal until you get 3/4 of the way threw it's stroke, then you get brakeing power but not enough to stop the truck?
Old Nov 13, 2011 | 06:53 PM
starmilt's Avatar
starmilt
If the rod is adjusted right to the master cylinder it should pump up, if it bleeds back down while you are holding pressure on it, the master is bleeding off, if it pumps up and feels spongy, their is still air in the system.
