Window Rust
Old 08-17-2009, 11:48 PM
rpenterics's Avatar
rpenterics
rpenterics is offline
Window Rust
So after my trucks saw its first Michigan winter, it has developed some rust (around the cab lights/roof area, and windows). I want to try to fix (to the best of my ability) the areas before this winter. So how do you remove the outside lower trim/seal on the windows?
Old 08-18-2009, 09:50 AM
Pocket's Avatar
Pocket
Pocket is offline
Pull straight up. But do it carefully so you don't bend it all to hell.
Old 08-18-2009, 11:03 AM
Mike F250's Avatar
Mike F250
Mike F250 is offline
Ryan, your location shows IA. Did you move to MI?
Are you talking about the rear doors where the window seal meets the corner?
I have checked out several trucks with the same rust spots. Plan to touch mine up too very soon. Also need to clean up below the lower door seals.
Old 08-18-2009, 11:06 AM
rpenterics's Avatar
rpenterics
Actually, I moved to IA in January - still missin' Michigan... I am talking about the window corner, only have one rusting so far, but it does seem to be common on these trucks.
Buck268
2009 - 2014 F150
31
11-24-2014 07:46 AM
ninerhb
02-05-2012 07:14 PM
ryanguy76
1999 to 2016 Super Duty
01-27-2012 11:00 AM
Ford-Plower
18
03-08-2009 03:19 PM
Tony Gonzalez
1978 - 1996 Big Bronco
07-02-2003 09:02 PM
Quick Reply: Window Rust
