General Automotive Discussion
Excursion 4X4 that Thuds when u stop
Old Aug 12, 2009 | 10:35 PM
vicalcmore2's Avatar
vicalcmore2
I have a 2000 Excursion 4X4 i have replaced the brakes, rotors, drag link bar, ABS hubs, rotated the tires, 5 new shocks. When I come to a stop at any speed there is a thud toward the back. I was told the leaf springs needed replacing by one mechanic, another said the yolk, and third mechanic said the leaf spring bushings, can anyone help????
Old Aug 12, 2009 | 10:45 PM
Chaosracing's Avatar
Chaosracing
Check the excursion fourum and post there. SOmeone might be able you help you out quicker there.
Old Aug 13, 2009 | 10:37 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It's often a dry slip joint in the rear driveshaft. Ford sells a teflon grease to fix this.
