Starting procedure after turbo replacement
Old Aug 12, 2009 | 08:41 PM
sparkignitor's Avatar
sparkignitor
I'm looking for advice on restarting my truck after the turbo has been replaced. It's been sitting for 7 mos. (really short of funds for the turbo) the batteries were disconnected during this time and coolant was drained. I read that I should cycle the key several times to prime the fuel system. Any other suggestions would be appreciated.
Paul
Old Aug 13, 2009 | 10:51 AM
npccpartsman's Avatar
npccpartsman
Paul
There's nothing you have to do other than what you said.
Old Aug 13, 2009 | 12:02 PM
misterc's Avatar
misterc
Some of the early truck need a VGT relearn procedure.
Old Aug 14, 2009 | 12:02 AM
sparkignitor
Thanks for the info. I wasn't sure if the re-learning process was necessary. I do a search for the procedure.
Old Aug 14, 2009 | 06:23 AM
npccpartsman
It's not necessary, but if you just HAVE to then disconnect the batteries, turn on the lights for 10 minutes AFTER that, then reconnect the batteries. I've swapped the turbo on my 04 several times and there's no relearn required.
Old Aug 14, 2009 | 10:37 AM
sparkignitor
No, definitely don't have to do it. Thanks for the head's up. I'm going to firing it up this weekend and hope I got everything connected up right.
Old Aug 14, 2009 | 08:37 PM
jboczar's Avatar
jboczar
I would recommend removing the FICM fuse and cranking the engine until you have base oil pressure on the instrument cluster and about 10 seconds past that to make sure the turbo bearings are sufficiently lubricated.
Paulsf350sdcc
Jun 19, 2014 08:20 PM
d00g13
New Member Introductions
Mar 25, 2014 10:49 AM
Machinist1
Bronco II
Jul 7, 2005 06:55 PM
Paul_no
1978 - 1996 Big Bronco
Aug 13, 2002 10:38 AM
ryanstruck
Dec 19, 2001 09:01 AM
