widest rear tire?
Old Aug 12, 2009 | 08:23 PM
70torino429's Avatar
70torino429
Question widest rear tire?
Whats the widest rear tire you can stuff under the back of one of these trucks with no clearance issue? on a 86' 2wd f150 for what its worth.
Old Aug 12, 2009 | 08:52 PM
Franklin2's Avatar
Franklin2
31x10.5x15 gets awfully close with a load of fire wood, but it just squeaks by the fender in the back. That's with a 8 inch aftermarket rim. If you run a stock rim, that size tire will rub the radius arm up front in the parking light.
Old Aug 13, 2009 | 08:59 AM
6CylBill's Avatar
6CylBill
11 inches with the 7.5 inch rim. I know; I used to run 27x11's. Seems like 11.5's are possible, but I don't know for sure. I do know 11 inches will work.
Old Aug 13, 2009 | 09:54 AM
Diesel_Brad's Avatar
Diesel_Brad
This is a quote from my Lightning forum he is using 17x11 rims and a 29.5 tall tire and 14.5 wide. and lightly massaged the wheelwells
Old Aug 13, 2009 | 10:00 AM
hoxiii's Avatar
hoxiii
It really depends on how you use the truck. With an actual load on a stock rim a 10.5 is about as big as you can get as franklin said.
No load, just as a play toy 12.5's look real good on a stock rim, stick out just a little.
Now if you start offsetting the wheel in towards the frame, you can pick up a bunch more.
I've run a 12.5 on a stock rim and it stuck out past the fender about 1" at the top. Keeping the lip in mind, you'd be at a 10.5 to actually get the tire in the wheel well with NO rubbing.
diamond mike
Nov 2, 2011 11:06 AM
OldBlue68
Jun 16, 2008 09:20 PM
mainevent223
Apr 29, 2008 08:08 PM
doc_f250
Jun 13, 2006 06:44 AM
icyford
Apr 15, 2004 08:48 PM
