Widest aluminium rims
04-11-2004, 03:21 PM
on
What are the widest aluminium rims you can get for a 2004 SuperDuty?
04-11-2004, 03:36 PM
Well I dont know about the wildest..But I have a 70 F250 I am going to put on the new ION I think there the 138 series 8 lug 16X10by6 1/2 and they look sharp..they make other sizes also...I found them in the Summit or the Jegs Cat..Good luck-Russ
04-11-2004, 03:49 PM
on
weld offers a 17" x 14"(wide) wheel
04-11-2004, 04:00 PM
I have'nt seen those..do you have a link? are the 8 lugs with a 6 1/2" bolt patern?
04-12-2004, 01:24 AM
on
04-12-2004, 10:45 AM
on
I have the 16.5x14 Weld Mountain Crushers on mine! What size tires are you wanting to run? This pic is with 39/18/16.5 Mickeys mounted on them.
04-12-2004, 12:25 PM
on
Quote:
before you order....
your wheels are 8x170mm..... not 8 on 6.5" like they used to be pre 99....
heads up!
04-12-2004, 05:09 PM
on
Size of tires
Well, currently I have 17" wide steel rims, they are modified standard rims as you can see here.
The tires Im using are Trxus STS 44x16x21.
Those will be winter tires with nails. Now I need rims for summer tires and I will probably be using same size tires.
thx
04-15-2004, 08:48 PM
on
This has nothing to do with rim size, but that is one badd *** excursion. We don't see much of that in PA with our friendly laws and all
BCHauler
1999 to 2016 Super Duty
09-18-2011 01:05 AM
geno001
1997-2006 Expedition & Navigator
10-20-2010 09:14 PM
shawn001
Appearance & Dress-Up
02-05-2005 08:45 PM
Aerodyamis
09-16-2003 08:38 PM
Explorer_Lightning Wannabe
12-15-2002 08:55 PM
