Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Useing oil
Old Jul 24, 2009 | 09:11 AM
bmuhlbach's Avatar
bmuhlbach
Useing oil
My Daughters 01 Escape 3.0 with over 140,000 miles started to use or leak oil a few spots on the driveway nothing that big.Goes thru a quart in 2000 miles. Any one know of a commen place that they may leak from seems to more on pass side alittle wet but i can't see any thing easy to spot where it may be leaking from.Thanks hope some one can help.
Old Aug 15, 2009 | 02:37 PM
aquanaut20's Avatar
aquanaut20
Check the PCV, if not venting crankcase pressure will cause leakage and oil loss.
Old Aug 15, 2009 | 07:59 PM
bmuhlbach's Avatar
bmuhlbach
Thank you for the reply I will change it out heard its a pain to get at but possible.
Old Aug 15, 2009 | 08:01 PM
aquanaut20's Avatar
aquanaut20
Yes, that is why people don't change/check it. Good luck....P
