torque specs
Old Aug 9, 2003 | 06:57 PM
spinellib's Avatar
spinellib
torque specs
does anyone know the wheel lug nut torque specs for 01 Navigator? Or the Expedition?
Thanks.
Old Aug 9, 2003 | 07:39 PM
tyger25's Avatar
tyger25
torque specs
I believe it is 110 ftlbs.
Old Aug 10, 2003 | 09:43 AM
spinellib's Avatar
spinellib
torque specs
thanks tyger
Old Aug 10, 2003 | 11:52 PM
BigMattXXL's Avatar
BigMattXXL
torque specs
I'm pretty sure Tyger's right - check on the wheel next to the lugs - on my '99, it says "100 ft/lbs" (or does it say it on the lugnuts? I can't remember...)
Either way, there's a good chance it's stamped into the actual lugs or wheel.
Otherwise, I wouldn't worry about torquing it to 110 lb/ft. Sounds about right.
I'll check tomorrow while I'm at work.
XXL
Old Aug 11, 2003 | 12:03 AM
tyger25's Avatar
tyger25
torque specs
I remember on the recall for the lugs coming off that the dealer would re-tighten to 110ftlbs. I believe '01 was covered in these years.
Old Aug 11, 2003 | 09:58 AM
buzzard's Avatar
buzzard
torque specs
XXL
The 12mm studs/lugs is about 20 ft/lbs less than the 14 mm versions. Regardless, there is always a "range" in a torque specification anyway and I believe 110 ft/lbs is probably a good number. I torque my 12 mm lugs to 100 ft/lbs.
Old Aug 11, 2003 | 09:17 PM
buzzard's Avatar
buzzard
torque specs
Looked it up in my specs manual:
12mm studs = 100 ft/lbs
14mm studs = 150 ft/lbs
14 mm were used beginning January 2000.
Old Aug 13, 2003 | 06:16 PM
spinellib's Avatar
spinellib
torque specs
thanks for all the help guys. One more (dumb) question: Can I measure the width of the stud to find out if it's 12 or 14mm?
Old Aug 13, 2003 | 09:25 PM
buzzard's Avatar
buzzard
torque specs
Easier way to tell is with a socket. 12mm bolts have 3/4" nuts and 14 mm bolts have 13/16" nuts.
FortyFords
Sep 17, 2002 09:05 PM
Monsta
Modular V10 (6.8l)
Apr 28, 2002 11:34 PM
rocky
Sep 5, 2001 09:19 PM
Guy
Apr 2, 2001 07:35 PM
safer
Feb 4, 2001 10:46 AM
