Tar removal
Old Aug 22, 2002 | 08:54 PM
jhopkinson's Avatar
jhopkinson
Tar removal
I'm looking for a good product to remove the stupid tar that gets splashed up from the tires. Does anyone know of a good product that wont hurt the clear coat?
Old Aug 23, 2002 | 01:20 PM
Carlene's Avatar
Carlene
Admom
Tar removal
Welcome to FTE,
There is a thread near the bottom on page 2 on removing tree sap that may have the answer.
Hopefully the following link will take you there? Not sure because I'm new to this.
[https://www.ford-trucks.com/dcforum/DCForumID66/44.html]
Old Aug 23, 2002 | 03:41 PM
BlueOvalFitter's Avatar
BlueOvalFitter
Tar removal
Try WD-40....works for me.
Old Aug 24, 2002 | 03:29 PM
ditchdigger70's Avatar
ditchdigger70
Tar removal
kerosene works very well not politically correct but be careful and it works very well its also cheap give it time to soak then it will just rub the tar off
Old Sep 21, 2002 | 04:49 AM
nobleman's Avatar
nobleman
Tar removal
I bought some Bird ****** and Tar remover years ago when a roofer had a little overspray over my car. 1000 tiny little annoying black dots all over it.
It didn't work. However, I remember a rubbing compound or "swirl mark" remover did the trick for me.
Turtle Wax has a new Bird ****** and Tar remover out now which I tried. It worked very well on the Bird ******, and removed the brown cigarette burn stain from a plastic step rail. All this and it left a nice "just waxed" shine. I have not had the opportunity, and hope I never do again, to try this product on tar.
Old Sep 21, 2002 | 01:46 PM
jagabom's Avatar
jagabom
Tar removal
GM also make a bug and tar remover that says is paint friendly.
Also paint thinner works but can't say what will happen to the paint
Jim
77 F150 XLT 400 no air
Old Sep 24, 2002 | 12:10 PM
Superbru's Avatar
Superbru
Tar removal
WD-40 works well. Smells good too!
Bru
2002 F150 Super Crew
Black 4X4 Lariat
5.4 Engine Ford Chrome Bars
Ford Bedliner
1979 Bronco 351M 75K orig.
Old Sep 24, 2002 | 01:05 PM
vettehauler's Avatar
vettehauler
Tar removal
kerosine and diesel are almost the same thing, I prefer them. Next on my list is WD-40, I think you have to use more elbow grease with wd-40 than with diesel. No matter what you use, you should follow it with a good cleaning and waxing.
Drew.
Old Sep 25, 2002 | 01:32 PM
superrangerman2002's Avatar
superrangerman2002
Tar removal
turtle wax makes a really good bug and tar remover.
I had to do both sides of my truck when my idiot friend took it trough a construction site at 50mph.
super
Old Sep 25, 2002 | 06:26 PM
jagabom's Avatar
jagabom
Tar removal
superrangerman2002, I hope your friend at least thanked you for borrowing your truck. Hey, can I borrow it ?
Jim
Old Oct 3, 2002 | 02:45 PM
Palani4Ford's Avatar
Palani4Ford
Tar removal
( Perhaps I should have afforded this topic its own thread, but this tar one is close enough in similarity )
What exactly are those tiny -- TINY -- dark red/brown, "black" specks on the paint which are so hard to elbow grease off ? It must be something in the air's moister content ( acidity ? ) that works on the finish over time. I didn't seem to have this problem when I washed and waxed the cars of my youth ( 30 or so years ago ).
My "new" white 2001 F-150 has them, and the white Mustang I rented in Maui a few months back had the same thing. These specks, or more apt, miniature freckles, are a bitch to remove. What product out there will work that won't harm the clear coat ? Will hot water assist ? Anyone ?
... The worst part is that they love to plant themselves in corners and crevices.
Palani
Old Oct 4, 2002 | 05:21 AM
spacecoast's Avatar
spacecoast
Tar removal
Try a clay bar on those spots. I dont know what they are but, if they are on the paint - clay should take them off.
Old Oct 6, 2002 | 07:42 PM
kyfordman's Avatar
kyfordman
Tar removal
I have personally used kerosene and it did a great job. Just like the other guys have said, make sure you give it a good washing when you are finished.
Kyfordman
Old Oct 8, 2002 | 09:57 PM
CobraXP's Avatar
CobraXP
Tar removal
[updated:LAST EDITED ON 08-Oct-02 AT 10:58 PM (EST)]Greased Lightning. Best cleaning product I have ever used. Spray it directly on the tar or whatever - right on the paint - then wash off with soap and water. Don't let it sit for a long time (more than 45 seconds), or it might get the wax, but it will get anything off.
I spray it on the spots, set the bottle down, grab the rag, dip it in the bucket, and wipe off. Comes right off...
Old Oct 9, 2002 | 03:25 PM
beartracks's Avatar
beartracks
Tar removal
All of these products will also remove the wax so a new coat would be in order after cleaning.
The Mothers clay bar treatment is amazing and even works on "dry" feeling finishes to return the slickness.
