mounting crossovers/front speaker boot
Old Aug 12, 2009 | 06:30 AM
iskatefast's Avatar
iskatefast
I am going to mount my crossovers under the center seat and need to get the speaker wire out of the cab , into the door....I'm a novice at this and it seems that there is no room to go through the existing boot??? Any help would be appreciated..
Old Aug 12, 2009 | 10:28 AM
FTE Trigger's Avatar
FTE Trigger
What model/year, cab configuration is this?
Some had the Harting plug which is a molded rectangular push in plug w/a lock or a simple rubber boot.
If its the basic rubber boot then you should have enough for at least 2-4 wires (if not more) depending on what options you have on your door.
In my experience i've had to use some wire pulling lubricant while fishing especially "tight" wires around the door.
...and Welcome to Ford-Truck Enthusiasts!
Old Aug 12, 2009 | 10:37 AM
iskatefast's Avatar
iskatefast
Thanks for the reply. I am mounting MB quart PVI 268 in a 04 Lariot Screw. I was looking at this last night and it seems that the pass-thru to the door is sealed? No room to add wires.....
Bill
Old Aug 12, 2009 | 04:58 PM
FTE Trigger
So I assume you don't have the typical rubber boot but the connector that looks to plug into the door?
You should have enough room if you have the boot. Simply fish a piece of coat hanger or fishtape (if you have it) through the passage. Then attach your wires in a staggered form on the wire then gently pull.
If you have the connector then you may end up having to add a set of pins and a section of wire(s) within the connector if you have the space.
Old Aug 13, 2009 | 06:37 AM
iskatefast's Avatar
iskatefast
Yeah , it's the plug. I have to take a closer look at it but if there is room, I may try to drill a hole in the plug....
86F150302
15
Dec 26, 2010 11:47 PM
ruschejj
Nov 23, 2010 10:36 PM
ekim17mr
Nov 15, 2010 02:19 AM
speckfisher
Electrical Systems/Wiring
Dec 26, 2009 05:43 PM
