brake fluid flush
Old Aug 12, 2009 | 02:20 AM
wallz's Avatar
wallz
brake fluid flush
Has any one else run into the front brake bleeder screws on the front calipers rusted shut. I mean rusted inside the hole that the fluid is supposed to run out of. Talk about a silly way to have those, facing up.
I did end up getting then off, and somewhat cleaned to be able to bleed the brakes, but was wondering if there is anything that you guys use to cover the holes up to prevent crud from getting in there again, and hopefully stopping it from happening for next time.
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old Aug 12, 2009 | 02:44 AM
Monsta's Avatar
Monsta
Sit. Stay.
The bleed valves should have covers on them. I imagine you can get replacements at any auto parts stores as the size is pretty universal.
Old Aug 12, 2009 | 09:18 AM
UrbanXX's Avatar
UrbanXX
You may very well may need a SCAN TOOL to bleed the brakes correctly if your truck has ABS brakes.
Old Aug 13, 2009 | 01:43 AM
wallz's Avatar
wallz
Ya I remember reading that post a lil while ago. It was more of a flush of the fluid that I could get to in the bowl and the lines. Hit a dirt road after and made sure that I got the abs working, and all seems good.
Our local napa didn't have anything to use as covers, so I ended up using some shrink tubing. Bending and shrinking over one end and shrinking onto bleader valves. Good to go till next time. Thanks Monsta, you !!
Old Aug 13, 2009 | 07:46 PM
RACERX7775's Avatar
RACERX7775
did my flush using the MOTIVE brake bleeder. WOW was it nasty. i thought that i was gonna run into the stuck bleeders. mine turned very easily though. i guess i got lucky.
cdat81986
18
Sep 14, 2022 08:02 AM
DodgeAddict
Large Truck
May 17, 2014 03:59 AM
Olds69442
6.7L Power Stroke Diesel
Feb 10, 2014 07:27 PM
BeachEx
Jan 23, 2014 03:24 PM
bigbadwolfe
Jan 12, 2014 11:11 AM
