i have a 95 fsuperduty with a cracked bellhousing my ? is i have a zf from an f350 i took apart if i take the t-case of and put the e-brake assembly on will it work with my drive shaft or do i need to get a new one
<input id="mac_address" value="" type="hidden">
Welcome to the Form
Punctuation, capitalization and spelling can go a LONG way
If I read you post correctly
"I have a 95 fsuperduty with a cracked bell housing. My question is, I have a zf from an f350 I took apart .If I take the t-case off and put the e-brake assembly on, will it work with my drive shaft or do i need to get a new one? "
Yes, you can use a 4wd ZF in place of a F-superduty ZF, BUT...
A couple questions need to be answered first
What engine in is the F-superduty?
What engine was in the F350 donor?
What year is the donor?
