2009 Navigation in 2005 SCrew
Old Aug 11, 2009 | 09:08 PM
Rob79's Avatar
Rob79
Will a 2009 navigation system with SYNC plug and play in a 2005 Ford Screw. thanks
Old Aug 11, 2009 | 09:43 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
no
the 2009's have a completely different radio style. so it won't even fit a 04-08 model
then you have the problem with the sync. Ford themselves can only get the Sync to work on select 2008 models. It's a $540 add-on-module
Old Aug 12, 2009 | 09:43 PM
Rob79's Avatar
Rob79
thanks tylus, glad I asked before I bought one off ebay
Old Aug 19, 2009 | 09:33 AM
BrianB31's Avatar
BrianB31
Also the 2007-2008 NAV system for the F series is not a direct bolt in for those of us with 2004-2005 trucks. The antenna connection was changed in 2006 so you have to get an adapter to use it in the 04/05 trucks. This is addition to the external GPS antenna.
Tcw89
Sep 26, 2014 03:54 PM
fordboy2
Sep 20, 2014 06:45 AM
mountainman101
2009 - 2014 F150
Mar 11, 2009 08:34 AM
Richard38
May 12, 2008 10:41 PM
kcinmd
Feb 24, 2008 07:12 PM
