Help Please................
Old Aug 12, 2009 | 10:17 PM
Old93junk's Avatar
Old93junk
You could try cleaning all the contacts on the ECM and the harness with electrical contact cleaner and re-installing................We all know what that dust out there does to things, Don!
Old Aug 12, 2009 | 11:58 PM
TexasGuy001's Avatar
TexasGuy001
Originally Posted by Volvo92906
Excuse me for interrupting but can I ask about this SPOUT connector. I got that it has something to do with spark. Lately ive seen it a lot and the book, instead of just saying "this does this" is sort of runs around it and involves all kinds of poking and prodding to test. Can someone explain what unplugging it does and when its plugged in what it does? Id appreciate that. Thanks!
The SPOUT advances the timing. So when its unplugged its like the vacuum advance on an older engine is disconected. If you are going to check the timing you need to unplug the SPOUT. I think the SPOUT also does something else.
Old Aug 13, 2009 | 12:00 AM
TexasGuy001
Originally Posted by alxsnmr
The Spout connector disconnects the computer control from the ignition module, thus disabling the timing advance and retarding by the computer.
Doesn't the SPOUT also do something else. I have heard it referred to as ignition diagnostic signal or something like that.
Old Aug 13, 2009 | 03:56 PM
alxsnmr's Avatar
alxsnmr
It is possible that it uses it as a diagnositic: if the spout is left out the computer will throw a code indicating that it can not find the spout. For all intents and purposes, it is for computer control of the spark timing.
Old Aug 13, 2009 | 07:26 PM
EPNCSU2006's Avatar
EPNCSU2006
The ignition diagnostic (IDM) is separate from the SPOUT circuit. SPOUT stands for SPark OUT. If the SPOUT is connected or removed with the engine running, it may set a code. I've never gotten a code when setting the timing, but I've never left it out for an extended period of time.
Old Aug 13, 2009 | 08:01 PM
Volvo92906's Avatar
Volvo92906
Ok, ok. Thanks for everyone responding to the SPOUT question but I didnt want to hijack this thread. It has to do with timing advance to control spark when engine is running. I just wanted to know just in case it ever came up. But, thanks.
LeRoy Coverdale Sr.
17
Jan 5, 2024 11:31 PM
perry b
20
Sep 14, 2016 08:22 PM
Yvan
1997 - 2003 F150
Mar 10, 2014 10:59 PM
theunderdog
Jun 1, 2012 05:00 PM
150philly
2004 - 2008 F150
Apr 28, 2011 04:54 PM
