'66 padded dash question
Old May 3, 2010 | 07:05 PM
Raider50's Avatar
Raider50
Originally Posted by William
Personally like a metal dash. Pull the rotten pad off, sand and paint the dash any color you prefer. Save yourself some bank!
Dose anyone have any pictures of their dash after they pulled it off and painted it?
Old May 3, 2010 | 08:36 PM
dadstruck's Avatar
dadstruck
I was in the same boat with mine. Used a puddy knife to remove the dash. It was in ok shape. Took it to a local upolstery shop and for $150.00 they recovered and reconditioned my dash. They matched up the vinyl and it turned out as good as new. I'm trying to upload a picture with no luck...but trust me it looks factory new. I looked at buying a new one ..to much $ and then thought about repainting it but the cracks would have looked bad. I am very happy about how this one turned out and you cant beat the price.
Old May 4, 2010 | 12:44 AM
TexasTornado66's Avatar
TexasTornado66
https://www.ford-trucks.com/forums/p...ictureid=33985
Old May 4, 2010 | 09:57 AM
Raider50's Avatar
Raider50
Originally Posted by TexasTornado66
Thank you very much. It dosnt look half bad. I think i know what i am doing this weekend.
Old May 4, 2010 | 11:34 AM
Flyn66dtmn's Avatar
Flyn66dtmn
My 2 cents. you can buy a padded dash for a 67 for about 75 bucks, 800 for the 65-66. insane to say the least. i have a friend here that is an upholsterer and he said it may be possible to put a cover over the original without pulling it. i need to replace the windshield anyway so am gonna try that before anything else. will let you guys know how it turns out. Dutch
Old May 5, 2010 | 07:22 AM
willy3486's Avatar
willy3486
I was in the same boat as many of you. I wanted to keep my padded dash but it was cracked really bad. It would even fold up in the middle.I figured out how to recover it and wrote a article in true blue trucks. I think it was the second one out if you can find it. It was extremely simple to do. I used a putty knife and heated the knife up with a heat gun. I then used that between the metal dash and pad to get the glue to give. After that I washed the pad with soap and let it dry for a day or so. I then filled up the cracks with RTV silicone and smoothed it out. I found a piece of black vinyl in a scrap bin at a fabric store. It was the kind that will strech somewhat and not as stiff as some vinyls. I then sprayed headliner glue on the dash and vinyl backside. I put the vinyl on the top of dash then wrapped it over the bottom of the dash. To hold it while it was drying I clipped it with plastic clothes pins. Then around where the speedo was to get it to fit I heated it a little with a hair dryer to get it to fit better. After that it was just fold over a little and trim a little around the edges. It fit good and has served me well for a few years. Total cost was about 20 bucks. Today it still looks good and the only sign it had of cracks is if you rub your hand over the dash you can feel some of the areas. But you can't see them unless you look really close.
Old May 5, 2010 | 08:28 AM
Flyn66dtmn's Avatar
Flyn66dtmn
thanks ***** for the update. we're gonna try and do it with the pad still in the truck, but the windsheild will need to be removed . i am going to put a new windsheild in anyway so it will be interesting. Dutch
Old May 5, 2010 | 10:11 AM
CropDusterMan's Avatar
CropDusterMan
There is a product used in aviation called "Pro-Seal", which is a two part flexable apoxy, it is almost identical to what is used to put in windshield glass-made by PPG.It could be good to use to fill cracks prior to covering.
Old May 5, 2010 | 10:18 AM
CropDusterMan
Hi *****,
If I decide to go with a removal of the padded dash in my '66 F250, are there any surprises waiting for me around the vents in the middle of the dash? Are these metal dashes that are underneath the same as the non-padded 65's? With this recent thread, I'm really thinking about recovering it, but I know these padded dashes can disintigrate pretty easy when removing, and a back-up plan is always good! ;o)
Old May 5, 2010 | 11:34 AM
willy3486's Avatar
willy3486
I have never pulled a 250 but mine is a 66. I think if you get the vents,speaker and the trim pieces at the end of the dash you will be fine. Just use a heated putty scraper to get between the dash and pad. if it does pull off chunks just squirt a little RTV between it and the piece that pulled out. Let it dry then recover. Its looks and sounds harder than it really is. It seemed easy to me. Good Luck
Old May 5, 2010 | 04:24 PM
CropDusterMan
Removing '66 F-250 Padded Dash
Thanks for the reply *****....
I'm going to shoot a video on removing it and I'll post it to youtube.com
I've restored several helicopters over the years, and I think that many of
those interiors were using the same vinyls and glues, foam etc...how hard can it be right?!
Appreciate the advice in this forum...what a great resource!
Best, Jason
Old May 5, 2010 | 05:12 PM
camperspecial65's Avatar
camperspecial65
The differences in the 61-6 dashpad vs 67 up pads is that the later pads are all bolt ons...you unbolt the old dash off of your rig and bolt a new one on. Or you send old cracked one and they redo it...they have a steel core that the pads manufactured onto making the core integral with the pad material.
Thats my guess why the later pads are cheaper then the earlier glue on types like the ones use on our trucks.
- cs65
Old May 20, 2010 | 03:42 PM
  #28
CropDusterMan
After the advice from people on the forum...I removed the old dash-pad and if you go to my albums, I have a complete step by step of it all.
Old May 20, 2010 | 05:08 PM
  #29
66f-100's Avatar
66f-100
Did you have any extra holes to fill in after removing the dashpad? Also, what did you use to remove the adhesive?
Old May 20, 2010 | 05:43 PM
  #30
CropDusterMan
66 Dash pad
There are no other holes to fill in, as the pad is only glued in place originally, and held on the edges by the trim pieces that you'll reinstall
anyways. The trim that goes along the bottom of the windshield hides
several small holes that didn't seem to serve any purpose...you just massage the trim into its clip holes and it hides them. Other than that,
it's very easy. As far as what to use to get rid of the glue, I tried acetone, and MEK worked ok, but ultimately, you'll have to sand the dash anyways to get rid of it all. You could use a razor blade carefully, but I hate to scratch the metal.
