How do you know when to do fuel filter?
Old Aug 11, 2009 | 01:00 AM
lucaslaw's Avatar
lucaslaw
pretty much what it says, how do you know?
Old Aug 11, 2009 | 01:36 AM
big poppa's Avatar
big poppa
Tuff question but a good one. I been keeping track of my fuel filter changes over the course of a 123,000 mile and trying to stay with the same fuel stations whenever possible, I can change mine at about 20,000 to 25,000 miles. They are a little discolored but not major dirty, if you get my drift. The fuel around here and where I used to live is fairly clean. Keep a log in your maintance book, it will help you to determine your intervals..
Old Aug 11, 2009 | 03:00 AM
orng1's Avatar
orng1
If you have to ask you've already gone to far, I say change it now fi you don't know when the last time was. I like to change mine at 15k miles since I travel far and pump where it's cheap.
Old Aug 11, 2009 | 06:11 AM
kirkharrod's Avatar
kirkharrod
If you have a fuel pressure gauge, it will show lower fuel pressure when time to change the fuel filter. Some people put a vacuum gauge in front of the filter. I have an electric fuel pressure gauge.
Old Aug 11, 2009 | 07:10 AM
riverrat41's Avatar
riverrat41
As Pop's said it is a very good question and can save you some heart ache and money down the road by keeping a good filter installed.I am really **** about maintenance on my trucks so I change my oil at 5k and fuel filter at 10k.This may be too often but I like to look in the bowl and see if there is anything in there plus a filter is a cheap way to keep things clean....Just my .02....Everybody is different and that is fine as well.
Old Aug 11, 2009 | 07:12 AM
rat49f6's Avatar
rat49f6
I know its overkill but I change mine with every oil change
Old Aug 11, 2009 | 07:23 AM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
just change it at the suggested interval of 15k miles and youll be fine. my fuel bowl filter is obsolete however since i have a regulated return and it came with a 2 micron pre-pump filter. ive been thinking about removing the bowl but i like the drain to help bleed any extra air out of the system.......
Old Aug 11, 2009 | 07:25 AM
riverrat41's Avatar
riverrat41
I do not see anything wrong with that.I do the same just every other OIL CHANGE.I keep all of it written in a book so I have a record of it and do not get out of order.
Old Aug 11, 2009 | 07:55 AM
agg_bagg's Avatar
agg_bagg
i do it every oil change also. its a small price to pay so i can sleep good at night lol...
Old Aug 11, 2009 | 08:06 AM
kirkharrod's Avatar
kirkharrod
Wow, that is a big waste of money, unless you have really bad diesel stations in your area, or you are getting the filters very cheaply.
Old Aug 11, 2009 | 08:08 AM
Izzy351's Avatar
Izzy351
Every oil change is probably a little overkill. Every other is pretty good if you go 7k or so on an OC. Since I have a pre-filter, I physically look at mine every OC and decide from there. It stays pretty clean with the pre-pump filter (which I change about every other OC).
Old Aug 11, 2009 | 08:12 AM
WA.Ranger's Avatar
WA.Ranger
Funny story- I ran a similar filter, forgot to change it after my first tank of B99, and freaked out when I was making my way from WA. down to CA. at 3am climbing some mountains. Truck started starving for fuel and I was half asleep. Learned to go every other oil change!
Old Aug 11, 2009 | 08:15 AM
Izzy351's Avatar
Izzy351
Yep -- mine saved my butt already. Got a load of bad fuel and about half way to work one morning it did what you're talking about. Popped into the parts store & replaced it with another and back on the road I was in 20 mins. If I didn't have the pre-pump filter, I imagine it would've been much more messy.
Old Aug 11, 2009 | 09:05 AM
brian42's Avatar
brian42
Veteran: Navy
I change the fuel filter every 2-3 oil changes.
Old Aug 11, 2009 | 09:58 AM
superduty4x4's Avatar
superduty4x4
Every 15k for me.
