Not given much thought, fiqure if there's space between the road and bottom of the rim, it's good to go. Certainly have loaded a heck of alot more than halaf ton, been occasion thought the tire was going to blow, or get stopped by CHP. Usually swear will not do it again until the next load.
Since on subject, just replaced the fronts shocks with Gabriel Loadlevelers, anything would have been an improvement, and not sure what to go with on the rears. Been looking at the Monroe loadlevelers, any suggestions appreciated!
..........not sure what to go with on the rears. Been looking at the Monroe loadlevelers, any suggestions appreciated!
Dave,
Have you considered looking into air shocks?
They can be aired up to help your springs with heavy loads, then aired down during normal use duties. That way you don't have to deal with a stiff ride 24/7.
Just don't blow an shock air line (i.e., rubbing against the exhaust) when you're heavily loaded! It could get UUUGGGLLY!
BarnieTrk
Appreciate the suggestion, had not thought about air shocks. Went online and found Monroe does offer them for the 65 F100. According to the item description they can be adjusted from between 20 to 150 psi. I will call them tomorrow and get additional info. Thanks again!!
Should you go with air, make sure you locate the valve stem (filler) in a convenient place so not to have to crawl under the truck for air adjustments.
John
Tnks John, it's for the flareside, if decide on air shocks (?), imagine somewhere in the wheel well area.
If you go with the air shocks, you will likely want the shocks to be pressure-filled equally. I think the easiest way to accomplish this is to join the two shock fill lines and Tee them into a single fill nozzle. I've seen most fill nozzles mounted at the rear/center, adjacent the trailer lights hookup socket. Depending on if you're concerned more about looks or function, you could protect the lines somewhat buy running the lines thru sections of old garden hose then clamping the hose up into the framework of the truck so it doesn't hang down.
