does anyone know who sells stuff for the 1 tons.the PO cut my cables with a torch,i have no idea my.i cant seem to find new ones on line,everything is for the 1/2 tons unless it fits all models.i have a 50 merc m-68.any help would be great,thanks
This company makes all kinds of custom cables if you have your old one, or have the specs you need to give them. http://www.push-pull.com/ Its where I got mine
I have an e-brake cable off of a 48 F3. I don't need it but am not sure if it fits your truck. Check it out and let me know. I will give it another look to see how good it is.
i pull the 3 cables off my 40 ford 1 ton,the 1 from the cab i think will work(by the time i finished with the axle i was to bummed out to try the front one).like i said the PO cut the 2 that go to each side of the axle,so i dont have the measurements of the cable to send to the push pull guys.
the cables that go in the backing plate have a clevis on the end that hooks on the e-brake lever and where it goes in the backing plate it is 2 flat pieces that sandwich the cable,with 2 ears???for the nuts and bolts.the f3sould be the same as the merc m-68,(as far as i can figure).i dont know where sandy run is but i guess UPS does.if your cables are in good shape how much would you want for themim not sure how it works or if you can maybe you could PM me.
thanks for the replies
I think I misunderstood what you needed. The cable I have is the front one that goes to the handle in the cab. I do not have the 2 rear cables. LMC Truck has them for a 48-52 F2.I think someone on this forum could tell you if the are the same for an F2 or F3. NUMBER DUMMY should know. That web site is lmctruck.com. Good luck.
i did see those on LMC site ,but with all the post in the last week or so about getting the wrong parts from them im a little shy about ordering from there,the pic they show is not the same as my cable looks so im not sure i want to go through the troble it i have to send it back.
