Symptom --- IAC?
Old Aug 10, 2009 | 02:01 PM
geodiggr's Avatar
geodiggr
Symptom --- IAC?
1992 F150 5.0 2wd Auto
When starting the truck cold, it starts, idles down almost to the point of dying, then picks back and idles high until warm when idles back to normal. There are some instances where I must give it gas to keep it from dying.
Friend suggests an Idle Air Control valve issue, however I am not sure that Ford has any such part.
Looking for suggestions right now...no codes.
Thanks,
Rick
Old Aug 10, 2009 | 02:14 PM
skaterbro's Avatar
skaterbro
Yes, your truck does have an IAC valve. It's on the throttle body behind the intake tubes. Take it off and see if it's dirty first. As far as codes, did you actually try pulling them or is it just that the CEL isn't on?
Old Aug 10, 2009 | 02:21 PM
geodiggr's Avatar
geodiggr
Yes, I pulled codes using the jumper method. CEL is not on after the truck starts, nor has it come on during the operation of the truck.
I will pull it off and see if it's dirty...
Would it cause that kind of symptom? I couldn't find it in my Haynes manual. Does it go by another name by Ford?
Thanks,
Rick
Old Aug 10, 2009 | 02:26 PM
skaterbro's Avatar
skaterbro
Nope, should be Idle Air Control Valve.
Old Aug 10, 2009 | 02:28 PM
quicklook2's Avatar
quicklook2
replace it with a ford iac.
stay out of autozone unless you need wax or oil but not parts.
Old Aug 10, 2009 | 03:01 PM
Volvo92906's Avatar
Volvo92906
It might be the map sensor. I bought a 1987 and when I started it, it would idle, drop to almost dying, catch itself, idle high, drop, catch. Sometimes it would die but if I gave it gas it was always fine. When it was warm it was fine. I replaced the IAC and it kept doing it. Then I replaced the TPS (the new TPS was bad from the store so I put the old one back on) I replaced the MAP sensor and it fixed it for good.
Old Aug 10, 2009 | 03:14 PM
AaronOregon's Avatar
AaronOregon
Thanks,
Rick
Try Idle Control Bypass
Old Aug 10, 2009 | 03:47 PM
SaikotikGunman's Avatar
SaikotikGunman
Know an '87 that did something very similar when the IAC was bad. After running for a few minutes, it would just keep idling high. If I put it in gear, it'd idle high enough to lock the TC up and move the truck at a decent clip.
Carl Tritch
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Aug 27, 2016 06:39 AM
2wilde4u
Mar 24, 2016 10:15 AM
MacPhly
Mar 18, 2015 08:06 AM
trevr6t6
Mar 7, 2015 08:11 PM
af11
Apr 20, 2014 10:38 PM
