axle up grade ?
Old Aug 10, 2009 | 12:31 PM
Darin Pierson's Avatar
Darin Pierson
axle up grade ?
looking to find out if using super duty axles work under a 78 F-250. Has anyone done it and how hard to make fit
Old Aug 10, 2009 | 12:54 PM
fordrealdrive's Avatar
fordrealdrive
well anything is possible, but as bolting them in & running thats a negative! the axel tubes are different lengths & the sd frames are much wider than the 77.5-79 f250s, it would probably be much cheaper to find a 78/79 high pinion D60 than to retube a sd frt D60 to fit the 77.5-79f250s, also you would then have the benefit of kingpin knuckles vs. ball-joints.
Old Aug 10, 2009 | 06:17 PM
monsterbaby's Avatar
monsterbaby
the other issue with the SD front is the unit bearing that ford went too. you can't repack them and to replace even at a good discount they run around $270 each.
Old Aug 10, 2009 | 09:42 PM
Darin Pierson
I know how they are put together. I just havent mesured or herd of enyone doing the swap. I'll mesure one when I go to work tomarrow.
winfordr
Apr 28, 2002 11:54 AM
tryppster
Mar 29, 2002 08:59 AM
mtflat
Apr 8, 2001 07:23 AM
Motorcraftsman
Apr 5, 2000 11:38 PM
jowilker
Jan 28, 2000 03:52 PM
