73-79 rotor/hub interchangeable?
Old Aug 9, 2009 | 07:24 PM
79FordBlake's Avatar
79FordBlake
I put new front pads on my 73 F100 today rear shoes are still pretty good. The previous owner used it so much with wore out pads that the rotor on the driverside is ate up on the inside. I have a 79 parts truck with good rotors. I was wondering if the rotor/hub assembely off the 79 F150 was the same as the 73 F100. Both are two-wheel drive. I know this is a noob question but I havent ever took the time to notice if they were the same or not. Thanks.
Old Aug 9, 2009 | 07:35 PM
montana_highboy's Avatar
montana_highboy
Should be the very same rotor.
Old Aug 9, 2009 | 07:47 PM
79FordBlake
Ok thanks, I was hoping it would be. You may remember a while back I was trying to sell this truck. Two-tone green 1973 F100. Well nobody wanted to give me what she was worth so im fixin her up and gonna drive it. Do you know where I can get mixture screws for the carb? It has the factory motorcraft carb. It has been overhauled but smokes from to much fuel, Im hoping the problem is the one mixture screw that is badly bent.
Old Aug 9, 2009 | 09:02 PM
Jermafenser's Avatar
Jermafenser
I just checked the parts catalog.
They will.
ALL 1973/79 F100/F150 2/W/D front end parts are interchangeable.
willydad
Oct 8, 2014 12:09 AM
Mi-Cyn
Aug 26, 2014 08:53 AM
perk_dp
2004 - 2008 F150
Nov 9, 2010 01:22 PM
supercab4x4dually
Jan 1, 2004 12:53 PM
rwsr50
Aug 24, 2002 07:37 AM
