Oil & Lubrication
magnetic drain plug
Old Dec 21, 2000 | 11:54 PM
bp460's Avatar
bp460
4wd Low
magnetic drain plug
Several years ago I read an article in FOURWHEELER magazine about a magnetic drain plug that allowed inspection and removal of metal chips without draining the engine oil. I also believe it did not require tools to drain the oil or inspect for chips. This bit of information is hiding somewhere in seven years worth of FOURWHEELER. It remains elusive. I would be very grateful to hear from anyone who has information or experience with this product.
Old Dec 22, 2000 | 07:22 AM
weatherguard's Avatar
weatherguard
magnetic drain plug
Chances are, if you remove the plug to inspect it, the oil will drain.
Old Dec 22, 2000 | 11:03 AM
mefsh's Avatar
mefsh
magnetic drain plug
Yes I know what you are talking about. I also remember the drain plug. It had two pins in the middle of it you could check with an ohm meter to detect metal in the pan that was across the two pins.
Old Jan 3, 2001 | 08:42 PM
davie's Avatar
davie
magnetic drain plug
There is an interesting article in my favorite woodworking tool site" Lee Valley.com" Letter section number 32.
They sell rare earth magnets that you can stick to your oil filter,the theory is that, as your oil moves through your oil filter, the magnet catches all them little bits of metal, when you change your oil filter, remove the magnet and stick it back on the new one.
The earth magnets have lots of uses but be careful they are extremely powerfull and if you get them to close to credit cards no more credit card, same with your tape deck etc..
Cheers Davie
Old Jan 6, 2001 | 07:20 PM
bigtoys's Avatar
bigtoys
magnetic drain plug
Justin Jones
Jun 17, 2016 12:23 PM
555 Studio
Mar 11, 2016 02:06 AM
sunny.richter
May 5, 2015 09:05 PM
FordTruckfan89
Apr 24, 2014 09:29 AM
Ed
Aerostar
Apr 9, 2005 03:39 AM
