Lifter Noise????????
Old Aug 9, 2009 | 08:59 AM
RUSTY50F1's Avatar
RUSTY50F1
Can the lifters be adjusted on a 2.8 V-6 made in the early 70's? I have one and they are REALLY noisy. Thanks RUSTY
Old Aug 9, 2009 | 10:07 AM
sparky's Avatar
sparky
Been a long time since I saw one but......... I seem to recall they are overhead cams so yes they are adjustable........ but then again my rememberer isn't what it use to be so your results may vary
Old Aug 9, 2009 | 10:56 AM
ALBUQ F-1's Avatar
ALBUQ F-1
The early '70's Ford 2.8L V-6 is a German design; is yours from a Capri? Anyway, they are OHV and have adjustable rockers. They have solid lifters and require regular adjustment.
Old Aug 9, 2009 | 11:16 AM
RUSTY50F1's Avatar
RUSTY50F1
How can you tell what it came out of? I was told it came out of a Mustang but not sure. It looks like a 289 Minus 2 holes.LOL
Old Aug 9, 2009 | 11:57 AM
ALBUQ F-1's Avatar
ALBUQ F-1
If it is a narrow angle V6 (60 deg instead of 90) and only has two exhaust ports for the 3 cylinders on each head (IIRC), it's likely the early German V6. They used them in Mustang II's and Pintos, I believe. Pull a valve cover gasket, it will be obvious if they are adjustable. These engines were known for noisy lifters, listen to a Bronco II sometime.
