Ok,
so I'm getting on the hwy just lightly excelerating. Just as I get on the hwy, the truck jerks like I locked up the breaks. The tack jumped and then it was fine. How do I trouble shoot this? is it the motor, tranny, ?????
Ok,
help
Like a hiccup?
Because if so, I had the same problem and it turned out to be my..
Originally Posted by SpringerPop
CPS?
Try this. Drive around close to home with your wipers on intermittent and see if it hiccups again, or flat out quits.
If it continully shuts down and starts right back up try pulling your chip and cleaing it and where it slides onto the ecm. Had this problem with my old banks chip. Using DP-tunner now, much better. Thanks to the guys on here.
If you cps is doing this will it trigger a ses light?because i was driving home tonight in the rain with the wipers set on the constant low speed position (second 1 down when u turn them all the way up).And i had the radio on and i was going down hill,and i noticed the truck felt jerky under light throtle i didnt think much of it.but i happend to look down and my ses light was on,then it went right off.i know i have the black cps in my truck,so im just wondering if that will triggeer the light..also im going to get my truck scaned tommoro what codes should i look for?thanks and sorry to hijack
Originally Posted by Stewart_H
Like a hiccup?
My wife drove it to work and then we whent out to dinner and it started to pulse, and then it stalled. It did restart but I'm going to get one as soon as the parts store opens and then replace it at lunch.
