header advice
Old Aug 8, 2009 | 06:05 PM
plastikosmd's Avatar
plastikosmd
header advice
currently building my motor (557 CI) for my 79 supercab. Need advice on best header for my application. Keeping mostly everything under the hood, stock. Frame over or under headers for the motor? pros/cons? long tube yes or no?
thx
Old Aug 8, 2009 | 08:12 PM
Darin Pierson's Avatar
Darin Pierson
what is a 557? when I did my headers ai was told long headers are better by all the shops around. better flow and horse power, if you y them into a single 3 inch gives a better low to mid torque and good scavedge to
Old Aug 8, 2009 | 08:31 PM
mark a.'s Avatar
mark a.
I'd look at a set of Mad Dogs.
Old Aug 8, 2009 | 10:46 PM
shadowviper12345's Avatar
shadowviper12345
Originally Posted by Darin Pierson
what is a 557?
a monster on steroids.
Old Aug 8, 2009 | 11:02 PM
plastikosmd
557 is a 460 80 over and stroked. generally 80 over is bout max on a stock block. I used a DOVE block after stonic testing it. It is my daily driver, so not looking to make it too wild, prob will be a torque monster.
thanks for the mad dog info...looked it up..still same issue..inside frame or fender? and pros/cons
Old Aug 9, 2009 | 01:13 AM
mark a.'s Avatar
mark a.
My opinion, outboard is the wat to go. Easy bends, no heat soaked starter to deal with & a straight shot back. Mad Dog use big tubes, L&L's are smaller. I don't know about Hooker but I'm sure the price would be steep.
Old Aug 9, 2009 | 01:16 AM
plastikosmd
thank you, will give them a call..still got some time as the custom pistons are takin a while to come in and the build C6 that will hoplefully stay together
Old Aug 9, 2009 | 02:33 AM
Darin Pierson
What crank are you stroking it with.
Old Aug 9, 2009 | 09:40 AM
plastikosmd
crank is 4.5, rods 4.440, where stock is 3.850 and 4.390. Went with a forged crank..prob a bit overkill in my application..also convereted the block from 2 to 4 bolt mains
Old Aug 9, 2009 | 10:22 AM
mark a.'s Avatar
mark a.
Is that your black truck ? If so how about starting a gallery? I'd like to see some pictures of it, it looks nice.
Old Aug 9, 2009 | 10:25 AM
peganit2's Avatar
peganit2
These look right for a 557" streeter; http://cgi.ebay.com/ebaymotors/80-96...=p4506.c0.m245
Or these; http://cgi.ebay.com/ebaymotors/Ford-...=p4506.c0.m245
They look nice and the price is fair.
Old Aug 9, 2009 | 11:24 AM
Darin Pierson
Yes it's my wee beesty. I'm working on my galleries but my wife has to help me so its a slow go.
Old Aug 9, 2009 | 11:56 AM
plastikosmd
thx for header link...I would guess that they fit even tho 80-96? ( as there was no 460 4wd in 1979)
Old Aug 9, 2009 | 12:09 PM
peganit2's Avatar
peganit2
All I know about that is that the headers from my 84 F250 2WD fit on my 77 F250 4WD with no mods on the left side, a major but easy mod on the right side and clearancing the crossmember, which I had to do on the 84's too. The headers point right at them.
You'll have to "ask the seller" a question to be more specific with your application.
Edit; I didn't read the first ad carefully enough. Oops. The second one looks like the ones you want.
I'm probably wrong considering the price but those look like stainless steel. Or very shiny mild steel.
Old Aug 9, 2009 | 12:12 PM
plastikosmd
thank you
