So I am in the middle of replacing my leaking steering gear on my 1988 E250 7.3 and have run into a couple of issues. The old one came out fine (except fighting the pitman arm). I have the new gear bolted in place, but.....
1. When I was lining everything up to bolt the gear in place I felt the steering column push up.....like it telescoped up. Now that the gear is in place the steering column is an inch short and won't telescope back down. Is there something that I am missing? Do I need to loosen something to get it to drop down the inch I need?
2. With the new gear in my steering wheel would be upside down with the wheels straight due to where the flat spot on the steering gear is. I am assuming that the gear and steering column will spin 360* continuously (no stops) when it is not attacked to the pitman arm. Is this correct? If so I can get the steering wheel close by rotating the gear/steering wheel 180* before attaching the pitman arm. I know there are some grooves in the pitman arm gear that line up with the larger teeth on the gear.
Thanks in advance for the help.
<!-- / message -->
The column is supposed to telescope. Give it a little persuasion with a hammer to get it to extend back out. If the column will only attach to the box in one spot, just hook it up. The gearbox has stops in it so it will not keep turning, turn it fully one direction, then the other way while counting the turns. DIvide that no. by 2 and turn the wheel that far to center. Nolw hook up the pitman arm. The pitman arm is keyed where it will go on in 4 spots. It will be nearly impossible to botch the pitman arm... 90 degrees out and it wont line up with the steering linkage.
Thanks, I will keep fighting with it. With it being van, it is hard to get any leverage on the column to pull/push it down. Before turrning it lock to lock I should hook up the powe steering lines and fill it with fluid, correct? That is what I was planning on, I didn't want to damage the gear.
and if you do end up with the steering wheel misaligned to the wheels, pull off the steering wheel and put it back on at the desired rotation, these vans allow that.
Gear is in and all is functional. No more dripping fluid on the driveway and having to refill it every week.
With the new gear I did end up with the steering wheel slightly off center. Glad to know I can pull it off and reinstall straight.
And thank you to the IDI section. I posted over in the van section last night and still nothing.
Me too. I even figured out how to not freeze while working on it. The van it too tall to fit in the garage (rear suspension sits 1-2 too high), but that didn't stop me...
