leaking windshield
Old Aug 7, 2009 | 11:37 PM
slayercr23's Avatar
slayercr23
leaking windshield
when it rains the water come in the to of the windsheild. could i use exspanding foam on it?
Old Aug 7, 2009 | 11:59 PM
Jmeyer1990's Avatar
Jmeyer1990
don't use that, look crapy.
get some silicone, or some new seals all together
Old Aug 8, 2009 | 01:36 AM
slayercr23's Avatar
slayercr23
well it was better then my frist idea. Ducktape. lol
Old Aug 8, 2009 | 06:07 AM
uncle.stosh's Avatar
uncle.stosh
There are no "seals" on the windshield. They use Butyl and a caulking gun when installing.
Do not use silicon either it is bad for the paint.
The only solution is to take it to a shop, have them remove it, and then re-install it with a new bead of Butyl.
Most reputable shops guarantee their work against leakage.
Old Aug 8, 2009 | 08:15 AM
FordNFishinLover's Avatar
FordNFishinLover
I used silicon on the inside of my truck to fix the left corner of windshield were it was leaking. Its doing just fine now!!
Old Aug 8, 2009 | 05:01 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
If it's leaking in the top two corners of the windshield, it may not be the actual windshield or butyl seal that's leaking.
There is a seam at the top corner where the "A" pillar and the roof meets. If the caulking gets bad in this seam, it will cause water to leak through the seam and around the windshield.
You can buy 3M's Auto Body Caulking and sealant from most any auto paint store, and this will fix the problem with the seams.
If the caulking is cracked, it would be a good idea to dig the old caulking out of the seam and redo it. Also check the "B" pillar seams, as this also can cause leaks at the back, and rot out the lower cab corners.
Don't use silicone, it is corosive to the sheet metal.
Old Aug 8, 2009 | 05:57 PM
Jmeyer1990's Avatar
Jmeyer1990
hey.
there is nothing wrong with ducttape.
and they make it in so many colors now...
you could probably get away with that
Old Aug 8, 2009 | 08:08 PM
slayercr23's Avatar
slayercr23
its leaking right in the middle
Old Aug 8, 2009 | 08:13 PM
Eddiec1564's Avatar
Eddiec1564
Never use expando foam to stop leaks, I did and that caused MAJOR rusting up along the driver side A piller/windshield area. For tempory fix, I used that foil AC duct tape and taped the top of the windshield. That tape holds up for a long while! So far 3 years on my Bronco2!
Old Aug 8, 2009 | 11:26 PM
slayercr23's Avatar
slayercr23
lol thanks ill try that if nothing else works. also going to get some pics on here to show you guys my new project (the truck).
Old Aug 9, 2009 | 06:20 AM
uncle.stosh
Originally Posted by Eddiec1564
Punta Gorda, FL
I just noticed that......
Pretty funny.
Old Aug 9, 2009 | 08:04 AM
Eddiec1564's Avatar
Eddiec1564
Gets better, about 20 miles west of me is a town called Routunda....
Old Aug 9, 2009 | 09:31 AM
ctubutis's Avatar
ctubutis
Not near me, but... Toad Suck, AR
http://maps.google.com/maps?q=toadsu...N&hl=en&tab=wl
Old Aug 9, 2009 | 10:44 AM
first today's Avatar
first today
How about... Dry Prong, La ? It is in north La around Monroe.
Old Aug 9, 2009 | 01:03 PM
Jmeyer1990's Avatar
Jmeyer1990
Ogallala Nebraska.
haha
