decoding axle/transfer case tags
Old Aug 7, 2009 | 06:13 PM
hogworkzinc's Avatar
hogworkzinc
DentsideAholics
Hello all & thanks in advance for the help. I have some tag numbers that I need help decoding.
These are from a 79 ish ford p/u. F150
Front axle differential tag: top line, 4 09 D9TA BCB
bottom line, 610068-3
Front axle differential web: 44 9F
Rear axle differential tag: top line, 3 54 D8TA ADA
bottom line, 603900-12
Rear axle differential web: 60 C-30255
Transfer case tag: top line, D9TA7A195 VA
bottom line, 3 17 79 205 66
I'm guessing the front axle is a Dana 44 w/ 4.09 gears & the rear is a Dana 60 w/ 3.54 gears. That's if both are unmolested. I know these axles were swapped in (8 lugs) & are not the originals. Anyway to verify what the gear ratios are? If these are whats really in it, there is no way the 4x4 will work w/out grenading the t/case.
Transfer case NP 205?
Thanks again for the help.
Mike
EndorphinJunky
Ford Truck Parts for Sale
26
Jan 12, 2017 01:58 PM
cigarxtc
May 12, 2011 02:26 PM
hogworkzinc
Aug 7, 2009 07:11 PM
Alpine6
May 11, 2007 03:53 PM
Ford heaven
Oct 28, 2003 11:41 AM
