trans temp
Old Aug 5, 2009 | 10:14 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
trans temp
How hot is to hot for the e4od and what would be an average temp just commuting. Thanks.
Old Aug 6, 2009 | 06:26 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Average is 60-100F above ambient temperature.
220F is the max for long term. For no more than 1/2 hour you can go to 250F with no damage. Don't go over 250F. These temps are in the pan or the test port, the line to the cooler will be MUCH hotter.
Old Aug 6, 2009 | 06:40 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
Thanks Mark. When mine is fully warmed up, it seems to run n the 160-190 range which is a little above the 100 plus ambient but still a decent amount below the max.
Old Aug 6, 2009 | 07:57 AM
Brown Falcon's Avatar
Brown Falcon
That's ok, but I'd think about getting a bigger trans cooler anyways.
I have one and my temps are usually between 140-160.
Don't let it get up to 210 or higher, that's when bad stuff happens...
Old Aug 17, 2009 | 08:18 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
I think I would like to put in a different trans cooler. I pulled our pop up camper back from Maine on Saturday, about a 4 plus hour trip, temps were close to 90F and the trans temp was 200 +/-F for most of it. I would rather have it in the 160-180 range.
What would be a good cooler to get and I should probably change the fluid, so what would be a good synthetic to use?
Thanks for any help.
Old Aug 17, 2009 | 09:38 AM
redone1's Avatar
redone1
I went with the True-Cool. Cant remember the model # right now, think it was 4367 or something like that. I second brown falcons advice.
My temps went down 30-40 degress when towing with the larger cooler. Haven't seem over 175 when towing yet. Cruising around empty it wont go over 150 and is usually just above 125.
The fliud i think is Mercon.
Old Aug 17, 2009 | 09:54 AM
CampSpringsJohn's Avatar
CampSpringsJohn
A larger cooler will help big time. I don't do any towing with my 02, so I still have a stock cooler. It runs at 150 when it's 90 out. I have amsoil synthetic in both trucks. Synthetic will lower temps a little. My 97 never gets above 180 when moving, even if it's 100 out. It does have a larger cooler from the factory. It's an F450 truck though. In town it will climb above 200-220, but drops back down when out on the highway. My 97 weighs in at over 13,000lbs too. As for synthetic tranny fluid, I don't think you'll go wrong using any of them as long as they are approved for the ford transmission.
Old Aug 17, 2009 | 11:50 AM
Brown Falcon
I highly recommend the Amsoil synthetic trans fluid. Really good stuff.
Old Aug 17, 2009 | 08:09 PM
joe_13894's Avatar
joe_13894
If your front seal hasn't been replaced, you will replace it soon if you run over 220F.
Old Aug 18, 2009 | 09:01 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
Temp never got that high, maybe 202F, but still to hot for what I want it to run at.
Old Aug 18, 2009 | 09:13 AM
granny_rocket's Avatar
granny_rocket
i might be in trouble....
i'm really hoping my gauge is wrong becuase driving on the highway this weekend with an 'empty load' (not towing anything), the tranny temp was hitting well above 200... It looks as if I have two tranny coolers. A stock and an aftermarket. Maybe its time for a new one??? Could it be cloogged? Why would the temps be so high unless the gauge isn't working...
how much damage could I Have done? its been like this almost since I got the truck and that was 2 years ago.
Old Aug 18, 2009 | 09:16 AM
CampSpringsJohn
Like I said, with my 97 going through town, and driving the back roads, it will climb over 200 pretty easy. It has a whole lot to do with not near as much air moving through the cooler at the slow speeds, and the constant shifting it does with all the weight I carry. I always disengage the overdrive when I'm driving below 40mph. I have 130,000 miles on it since it was rebuilt. I was told I'd be lucky to get 100,000 on it. My truck was the first one these guys had rebuilt where they went with amsoil synthetic. Not saying it is the reason it has lasted this long, but it has lasted longer than what the mechanics said it would last.
Old Aug 18, 2009 | 09:22 AM
CampSpringsJohn
I'd say you have a faulty gauge. 200 plus when empty is quite high. It should never go more than 100 degrees above the outside temperature unless you're driving through town in a lot of stop and go traffic. The factory temp gauge in my 02 jumps up to normal operating temperature just sitting in the sun when I start it. The gauge I had installed says 100 when sitting in the sun.
If it's been doing that for 2 years, and if the gauge is correct, you would have destroyed the transmission long before now I would think.
Old Aug 18, 2009 | 09:34 AM
redone1's Avatar
redone1
That sounds high to me. I've never seen those temps running empty on a highway. even when I just had the stock cooler on. Now, with the larger cooler in (removed the old one completely) I can run on highways and never reach 150. Even lots of city driving doesn't rise mine above 150.
You may have a clogged cooler like your thinking. I would pull both of them and take a look. More than likely it's the stock one with the problem. Also a good idea to change tranny fluid and filter if you haven't done it for a while.
Old Aug 18, 2009 | 11:08 AM
Brown Falcon
It is very possible your stock cooler is clogged. A lot of people just removed the stock cooler all together and just us an aftermarket with great results.
