quick heater hose routing question
Old Aug 4, 2009 | 08:32 PM
Volvo92906's Avatar
Volvo92906
Ok, 88 F-150 I6.
When I got it there was no heater core in it.. Didnt need it. Now I do. Replacing it was the easy part. I have a hose looped in the route for the heater hoses. Now for the hard part...
Where do the hoses go? I dont have a diagram. I have one coming off the thermostat and one coming off the water pump. I guess the easiest way to put it is the heater core has a left and right pipe. Im just using aftermarket coolant hoses.. Not the things they want 25 bucks a piece for.
The heater core has 2 pipes coming from the top 'reservoir' on it. So, im not sure which one is the inlet and which is the outlet, or if it even matters. If anyone has input it would be awesome. To my knowledge this is the 4th heater core (I finally padded it as the others have failed because of bouncing around on the trails) I dont want to screw something up by hooking it up backwards.
Thanks in advance.
Old Aug 4, 2009 | 08:55 PM
F150xlt's Avatar
F150xlt
On my 88 F150 with the 300 six, the heater hose from the thermostat housing goes to the heater pipe closest to the passenger fender. The heater hose from the water pump goes to the heater pipe closest to the engine.
Not sure it really matters. On my truck there is no heater control valve.
Old Aug 5, 2009 | 02:28 AM
Sportruk's Avatar
Sportruk
No Ford truck for the past 30 years has had a heat control valve.
The Ford shop manual shows the water pump hose goes to the fender side and the thermostat housing hose to the engine side.
Old Aug 5, 2009 | 09:39 PM
F150xlt's Avatar
F150xlt
What is this?
http://www.rockauto.com/catalog/rafr...1372441k380393
Old Aug 6, 2009 | 07:22 AM
Sportruk's Avatar
Sportruk
Originally Posted by F150xlt
It's not a part that goes on an F150. Don't beleive aftermarket parts supplies listings. Ford controls there temps with a blend door, mixing warm and cold air.
eenyok
Jan 4, 2022 09:34 PM
Fixnstuff
Nov 12, 2018 11:23 AM
Blanketr
Feb 5, 2016 05:20 PM
Blanketr
Feb 3, 2016 10:21 AM
MikeD1980
Jan 23, 2011 11:10 AM
