Looking for the correct name of the part (solenoid/switch) between the vacuum port on the intake/TB and charcoal canister. It has a vacuum line connected to it on both sides and a 2 wire electrical connector on top.
Also, would a failure of this cause a rough idle/miss?
Failure of the purge selinoid would lead to a high idle condition. Rough running and a miss condition is either ignition, fuel, or compression related.
