Stock top speed??
Old Aug 4, 2009 | 06:15 PM
Lukes66's Avatar
Lukes66
Stock top speed??
I keep reading that these trucks have a top speed of 50 -55 mph. I just bought a 52 with a OHV I6 and 4 speed transmission. I was hoping to use it for commuting when the weather is nice but 55 isn't gonna cut it. Whats the deal, are they geared real low, or are they just real under powered? Will a M5OD bolt up to the early I6, would the over drive or a higher ratio rear help?
Old Aug 4, 2009 | 06:28 PM
deyomatic's Avatar
deyomatic
I think it's a combination of very low gears and fairly low revving engines. I think the tires were smaller back then, too. At least smaller than the last 10 years. My '60 has a 27" tire with 3.73s, my '05 has a 31.6" tire with 3.73s and OD.
Old Aug 4, 2009 | 06:33 PM
51MHF5's Avatar
51MHF5
Not sure what "these trucks" means but the 49-51 shop manual has the following rear end specs:
F1: 3.92, 4.27
F2-F3: 4.11, 4.857
F4: 5.83, 5.14, 6.66
F5 and larger: 5.14 up to 9.04 with the 2 speed rear end.
Rab
Old Aug 4, 2009 | 07:18 PM
WALFORD'S 56's Avatar
WALFORD'S 56
My 53 has the six and a 3 speed with 3.73 gears and runs fine.
It went 80 on the freeway...and I drive it at 50-55every day.
If you need more speed ....look at a big block or a new truck....LOL
Old Aug 4, 2009 | 08:10 PM
BlueOvalRage's Avatar
BlueOvalRage
There's not a prayer of the M5OD fitting your 215. The M5OD has a small block Ford bellhousing. The only way that you'd pull that off is by installing it in tandem with a 300 c.i. 6 cyl. out of a later truck, but rumor has it that they don't fit very well. There was an OD manual transmission available that would fit the 215, but they are pricey and getting hard to come by. Do a search and you should come up with a fairly recent thread that will tell you everything you need to know (if you can pick your way through the petty squabbling).
The easiest and least expensive thing you can do at this point is swap in a 9" axle out of a '67-'72 F-100 with a 3.50 or 3.73 gear ratio. Read the stickys for info on the swap. I wouldn't go with anything numerically lower than a 3.50 or that little 215 will have trouble getting out of its own way.
Old Aug 4, 2009 | 08:40 PM
Tumblindyce's Avatar
Tumblindyce
I drove my '60 F100 down to the spring shop on Friday to have the front springs rearched and a leaf added. My friend followed me there to give me a ride back. I had him clock my speed, because I wasn't sure if my speedo was right. When my speedo read 60mph, his read 63. I have the 223 w/3-speed on the column. It did just fine cruising down the freeway.
Old Aug 4, 2009 | 10:13 PM
4tl8ford's Avatar
4tl8ford
Define Top Speed
Straight and level 4th gear and standard rearend?
or In what we call Kentucky Overdrive - after cresting the top of the hill - kick it in netural and hope the brakes hold up - which the don't have a prayer of doing.
Old Aug 5, 2009 | 09:36 AM
deyomatic's Avatar
deyomatic
Lukes,
I have no idea where you live, but the aforementioned '60 F100 (292/Fordo/3.73) would do 65 on the highway fine (no tach so maybe it had more) but that won't cut it in my neck of the woods for commuting. It was like a scene in a movie, EVERY other car on the road passed me like I was standing still.
Old Aug 5, 2009 | 09:44 AM
53OlderThanMe's Avatar
53OlderThanMe
Originally Posted by deyomatic
Lukes,
They were just trying to get a look at your cool truck.
Old Aug 5, 2009 | 10:37 AM
deyomatic's Avatar
deyomatic
I like that answer...but that particular finger isn't USUALLY a complement!
Old Aug 6, 2009 | 07:19 AM
r_reed's Avatar
r_reed
another factor to consider is the solid axle technology, if you are retaining it. even with a refreshed suspension, a bump road or with a lot of traffic, i would be white knuckling it at 60 mph in my stock f-1. dick r
68fish
26
Aug 24, 2016 08:42 PM
rterril02
Apr 28, 2016 12:54 AM
Savagediver31
32
Jan 4, 2016 04:43 PM
Central Texcursion
Jul 1, 2013 08:13 AM
phillips91
Apr 14, 2008 04:20 PM
