basics please
Old Aug 4, 2009 | 03:56 PM
Tyronesdude's Avatar
Tyronesdude
basics please
I'm a new owner of an old stepside PU ('73). Some question about year of manufac-- one old registration had it as '71, most recent called it a '73. Where can I get facts, using VIN, and what is the location of the engine stamp? It runs well enuf when it runs, but sometimes it just dies. As if it weren't getting gas. Carb was serviced & partially rebuilt, mechanic can't figure out why it does that or why, after waiting half-an-hour, it cranks right up again. Any help appreciated.
Old Aug 4, 2009 | 04:02 PM
USArmyTaterness's Avatar
USArmyTaterness
The vin is the best place to start just post it here and people can decode it for you with out a problem. As for the engine do you have enough fuel pressure is the carb float saturated is it 2bbl or 4bbl has some moron decided to ram down all adjustment screws. ect.
Old Aug 4, 2009 | 04:06 PM
Tyronesdude
Hey, thanks! VIN is F25YRS21588. I'm too new to know whether 2bbl/4bbl but will find out.
Old Aug 4, 2009 | 04:10 PM
USArmyTaterness
another place to get information liker what tranny you have and the axles would be to look at the info plate on the door. it is not your VIN plate but close it will have all the information on what is on your truck assuming parts havent been swapped out.
Old Aug 4, 2009 | 04:11 PM
USArmyTaterness
Here is what I found on your truck
Model Year: 73
Series: F250 - 4x2 Pickup
Engine: 8 Cyl, 360ci, 2bbl
Assembly Plant: San Jose
Transmission: No code selected
Front Axle: No code selected
Rear Axle: No code selected
,y guess is you proabably have a 9in rear end the easy way to look at that is roll under look at the bottom bolt on the diff cover first off if the diff cover is facving the engine and secondly if you can get a wrench and socket on that bottom bolt on the diff cover. if you cant you have a 9in
Old Aug 4, 2009 | 04:33 PM
Witty73's Avatar
Witty73
Wouldnt be a 9 inch in a 250
Old Aug 4, 2009 | 04:47 PM
USArmyTaterness
yeah i guess thats true osrry bout that sometime I stop thinking
84espy
17
Jul 8, 2013 08:33 PM
CraigWettstein
Arizona Chapter
Feb 17, 2011 10:57 PM
Rusty_Old_F250
Engine Swaps
23
Jan 25, 2011 07:38 AM
Fullcrew7.3
Jan 1, 2011 12:04 PM
Luddle
Jul 30, 2008 11:06 PM
