HELP!!! Please
Old Aug 4, 2009 | 09:34 AM
g_rat84's Avatar
g_rat84
HELP!!! Please
Drove my 2004 F150 home from work last night - no problems. Started to take wife out to eat and truck would not start. When the ignition was turned I got nothing, much like a very weak or dead battery. Came back from dinner, hooked up battery charger and charged battery. Tried again. When ignition switch is turned on (before engaging starter) all the dash cluster lights would come on as usual then they would go off and on much like someone was connecting/disconnecting battery cable. Speedometer and tachometer would also show truck turning approx. 3K RPM and doing about 65 MPH....without being cranked. Could this be a bad battery, relay, or what? Please help with this as I need my truck running ASAP.
Thanks
Old Aug 4, 2009 | 10:13 AM
8UP's Avatar
8UP
First things first, have your battery load tested. Check your termonals & make shure you have a good ground & everthings tight.
Hope this helps.
(My guess is the battery)
Old Aug 4, 2009 | 11:00 AM
thirsty99's Avatar
thirsty99
Yup Need a new battery. These trucks do really strange things when the batteries go south. Lights go on\off, gages sweep, that sort of thing. Freaks you out the first time it happens.
Old Aug 4, 2009 | 11:12 AM
Still Smoking's Avatar
Still Smoking
I have heard if its a bad battery it will do funny things with these trucks. Kinda like what you have described.
Old Aug 4, 2009 | 02:16 PM
greenbullitt's Avatar
greenbullitt
bad battery or ground. i bet battery first
Old Aug 4, 2009 | 04:17 PM
Oldguy4's Avatar
Oldguy4
If you put the battery charger on it and it still acted up, I'm guessing a bad battery connection. It could be at either end of the two cables. But have things tested before just going out and throwing new parts at it.
Old Aug 5, 2009 | 08:44 AM
g_rat84's Avatar
g_rat84
Thanks to everyone who replied. I tested the battery, alternator, etc. last night. The battery was the problem. Replaced the battery and now the old girl is purring again.
Old Aug 5, 2009 | 10:53 AM
bridge's Avatar
bridge
Sick 'n Tired
Indeed, glad you got her working again. For future reference (and to help others who use the search function and find this post), anytime the gauge cluster does something weird at startup, like blink or the needles sweep back and forth, it's 99.9% of the time because of a weak battery that needs to be replaced.
Jftruck150
2009 - 2014 F150
Oct 6, 2019 11:21 PM
drewduncan15
Aug 4, 2012 11:14 AM
pjohnson2682
Sep 3, 2011 08:58 PM
rutang
1983 - 2012 Ranger & B-Series
Jan 7, 2010 11:35 AM
onebadz
32
Dec 9, 2009 10:34 PM
