Drove my 2004 F150 home from work last night - no problems. Started to take wife out to eat and truck would not start. When the ignition was turned I got nothing, much like a very weak or dead battery. Came back from dinner, hooked up battery charger and charged battery. Tried again. When ignition switch is turned on (before engaging starter) all the dash cluster lights would come on as usual then they would go off and on much like someone was connecting/disconnecting battery cable. Speedometer and tachometer would also show truck turning approx. 3K RPM and doing about 65 MPH....without being cranked. Could this be a bad battery, relay, or what? Please help with this as I need my truck running ASAP.
Thanks
First things first, have your battery load tested. Check your termonals & make shure you have a good ground & everthings tight.
Hope this helps.
(My guess is the battery)
Yup Need a new battery. These trucks do really strange things when the batteries go south. Lights go on\off, gages sweep, that sort of thing. Freaks you out the first time it happens.
If you put the battery charger on it and it still acted up, I'm guessing a bad battery connection. It could be at either end of the two cables. But have things tested before just going out and throwing new parts at it.
Thanks to everyone who replied. I tested the battery, alternator, etc. last night. The battery was the problem. Replaced the battery and now the old girl is purring again.
Indeed, glad you got her working again. For future reference (and to help others who use the search function and find this post), anytime the gauge cluster does something weird at startup, like blink or the needles sweep back and forth, it's 99.9% of the time because of a weak battery that needs to be replaced.
