1981 351w PCV configuration
Old Aug 4, 2009 | 12:31 AM
coho99's Avatar
coho99
At the rear of the pass side valve cover I have a PCV valve sticking out of the vlv cover with a piece of 6" hose attached. The other end of the hose is not connected to anything, not does it appear anywhere that there is something to attach it to. On the drivers side there is a hose coming from the oil filler cap to the air cleaner. The (PCV?) filter in the air cleaner has a fair amount of oil in it.
Is this the correct set up? Should there be some sort of intake air filter on the pass side?
Thanks for your help
Old Aug 4, 2009 | 11:07 AM
loudfords's Avatar
loudfords
PCV should connect to a 3/8"ish nipple under or on the carburetor. The line to the air cleaner is the breather/filter. Get a new filter insert to replace the one full of oil, or just get one of those aftermarket filler/breather caps.
Old Aug 4, 2009 | 10:49 PM
coho99's Avatar
coho99
Thanks...... I double checked there is no 3/8 nipple back there either on the carb or the manifold to connect to the PCV hose.......there is the choke vaccum nipple capped off after I installed a manual choke. could I connect the PCV hose to the choke vacuum nipple?
Old Aug 5, 2009 | 11:21 AM
loudfords's Avatar
loudfords
What kind of carb are you running?
Old Aug 5, 2009 | 12:22 PM
coho99's Avatar
coho99
The tag is gone (its been rebuilt at some point) as far as I can tell it is a motorcraft 2100 or 2150 2 barrel. I'm emissons exempt. 1.21 jets, auto trans, no air, Class C motorhome, Chateau "Camper Special"
Thanks
Old Aug 6, 2009 | 12:17 AM
Beanscoot's Avatar
Beanscoot
Ford engines usually come with a spacer between the carb and intake manifold that has the connection for the PCV hose. Are you missing this spacer?
Old Aug 6, 2009 | 12:21 AM
coho99's Avatar
coho99
Yes there is no spacer with with nipple on it....there is a thick 1/2"(?) black gasket but no metal spacer with a nipple like I've seen in pictures
Old Aug 6, 2009 | 12:05 PM
coho99's Avatar
coho99
So, it looks like the carb has been re-installed without the carb spacer with PCV nipple....my question is can I reduce down the PCV hose and connect it to the choke vacuum nipple which is currently not being used?
Thanks in advance
Old Aug 6, 2009 | 12:26 PM
Conanski's Avatar
Conanski
Vacuum is vacuum.. really doesn't matter where on the intake system it's attached.
aedinius
Apr 24, 2015 12:04 AM
LARIAT 85
65
Apr 21, 2014 05:12 PM
ksvtwin
1983 - 2012 Ranger & B-Series
Mar 14, 2014 04:51 PM
hooler1
Apr 16, 2011 11:00 PM
Quantum77
Nov 8, 2010 07:49 AM
