1978 - 1996 Big Bronco
Need help
Old Aug 3, 2009 | 06:47 PM
04redstroker's Avatar
04redstroker
Need help
I have an 89 bronco which has been sittin for a few years. It ran good until i blew the rear end up and it had to sit for a few months while i saved to fix it. Once i got it back together i only drove for a few miles when it just died. No sputter or anything. Checked and i had no fuel pressure. Couldnt find any bad relays or anything, so i ran a hot to the pump, i got pressure and spark but still wouldnt fire. Couldnt figure it out and i had another DD and no money so i gave up.lol I want to get it runnin again, but other then the bigger mess from it sittin, where should i start for the previous problem, im sure i missed somethin simple. Sorry for the ramble, but in doin this ffrom memory. If i cant figure it out, i might just swap to carb., and info on a good stand alone turn key ign. set up would be helpful also.
edit: its a 5.8 efi
thanx ahead of time,
cody
Old Aug 3, 2009 | 07:18 PM
g_k50's Avatar
g_k50
Will it start with starting fluid in the air box?
If yes, it's a fuel delivery problem.
If no, it's a spark/timing, distributor, coil problem.
What was your fuel pressue psi?
Old Aug 3, 2009 | 07:30 PM
04redstroker
I cant remeber. its been a while since i messed with it, and since i look at it every day, i figured its time to start workin on it again. I will hopefully have time to take it to my shop this week, so ill get some more info for you to work with. I hadnt tried the starting fluid, but as of a few weeks ago, it still turned over and there was some spark
Old Aug 3, 2009 | 09:10 PM
greystreak92's Avatar
greystreak92
I'd pull codes to be certain. The PCM will store codes indefinitely as long as the battery hasn't completely died.
Old Aug 3, 2009 | 09:31 PM
Conanski's Avatar
Conanski
That truck has 2 fuel pumps.. 1 in the tank and 1 on the frame, and the both have to work to build the required 40psi at the fuel rail.
Old Aug 3, 2009 | 09:52 PM
Mustang6147's Avatar
Mustang6147
dont use starting fluid... Pour a little gas in the air cleaner box.. That will start it with out wrecking the cylinder. Gas fumes run the engine not the liquid...
Honestly... It has been sitting, I would seriously start with simply cleaning every ground up. Check the harness going to the fuel pump ect.
The relay for the fuel pump...
Start simple. DOnt make a mountain out of a mole hill.
Maybe even a mouse or somethin called it home for a bit??
Old Aug 17, 2009 | 12:00 AM
jesse24spd's Avatar
jesse24spd
recheck the relay marked electrical. pop the cap off of the relay itself and check for internal corrosion. This will also cause your fuel pump to stop.
Old Aug 19, 2009 | 04:08 PM
NWBronco's Avatar
NWBronco
Also check the fuel shut-off switch. Not sure where it is on an '89. My '86 has it top of the transmissiom hump on the passenger side. Our old '92 had it behind the passenger side kick panel. If the shut-off trips, the fuel pump circuit is disabled.
Old Aug 19, 2009 | 07:23 PM
04redstroker
the shut off is on the 89 is behind the pedals on the drivers side. First thing i had checked. Still havent had time to work on it though. Thanx for all yalls advice
MacD1976
Jan 8, 2015 10:12 AM
bad87150
22
Dec 9, 2014 01:01 AM
RideDiesel88
Sep 9, 2013 06:29 PM
289FAN
Sep 7, 2011 08:39 PM
highboy
Apr 16, 2006 07:56 PM
