GEAR OIL?
Old May 25, 2011 | 09:45 AM
289FAN's Avatar
289FAN
GEAR OIL?
I just bought a '66 f100 with a 352, 3 speed manual. Its been sittin for a few years so the first thing i'm gunna do is swap ut all the fluids. I'm just not sure what trans oil and gear oil for the rear end i should put in it. Anyone have anything they usually go with?
Old May 25, 2011 | 10:35 AM
arctic y block's Avatar
arctic y block
Trans and Def should call for 80W-90W gear lube. I like Slick 50 myself.
Old May 25, 2011 | 01:06 PM
289FAN's Avatar
289FAN
THANX FOR THE INFO
Old May 25, 2011 | 01:17 PM
finneys98xj's Avatar
finneys98xj
I used valine syn-blend gear oil with limited slip. Quiet Really queit
Old Sep 5, 2011 | 11:08 PM
BeerKnurd's Avatar
BeerKnurd
Fellas, are multi-weight gear oil frowned upon for the manual tranny and diff? (ex. 80w-120w)
Old Sep 7, 2011 | 10:42 AM
66 4x4's Avatar
66 4x4
I just went to napa to get straight 50 weight for my dana 24 transfer case, they only have 5 gallon at a 139.00, i guess i will go muti weight with lucas additive.
Old Sep 7, 2011 | 01:06 PM
daveengelson's Avatar
daveengelson
Not an authority, changed transmission; T18 4speed, and rear axle with GL-5 gear oil with limited slip additive and later told the limited slip additive is corrosive for synchro gears. If understand correctly the GL (gear lubricant) has a rating from 1-5 and each has a specific characteristic for type of gears, additives, etc. I subsequently changed the trans oil to GL-4. Seem to recall a few weeks back a member posted a simular thread and a number of members recommended using a non additive gear oil. Anyhow, food for thought.
Old Sep 7, 2011 | 04:12 PM
Jetcopterpilot's Avatar
Jetcopterpilot
The ford Service manual calls for 50 weight, plain old 50 weight. 80 or 90 weight will make shifting a bit more difficult, aka slower, but will cause no harm.. anything over 90 weight is too thick aka not viscous enough. You want to find a non detergent oil, as any additives can cause corrosion on the brass, and copper internals! Multi weight oils have a modifier to make them blend better, which is essentially a detergent aka emulsifier so avoid those... you definitely do not want any GL rated gear oils! Just get plain old 50 weight... It will take a bit of searching but you can find it!
Old Sep 7, 2011 | 06:18 PM
BeerKnurd's Avatar
BeerKnurd
Jet, what are your thoughts on Pennzoil Synchromesh. This is what my Napa store recommended.
Thx
Old Sep 7, 2011 | 06:58 PM
Jetcopterpilot
Read the label on the Pennzoil, you are looking for any additives, or high sulphur content... those are a no no! I just researched it, and it is made using a 5W30 weight non detergent motor oil, with additives and modifiers to make it act like a 50 weight. It is designed for transmissions that are all aluminum, and steel based , it was designed for the NV4500 series transmissions, it will give you very smooth shifting, but my fear is that the additives will cause premature wear of the brass and copper bushing aka bearings in the older Ford Transmissions.. It will probably perform just fine, but it may induce early trans failure.
Old Sep 7, 2011 | 07:17 PM
BeerKnurd's Avatar
BeerKnurd
Went by Napa and no 50 wt available. The Pennzoil Syncromesh rear label reads: "it provides excellent oxidation stability, low temperature performance, synchronizer performance and is compatible with yellow metals such as bronze, brass and copper components found in manual transaxles and transmissions."
Old Sep 7, 2011 | 07:23 PM
Jetcopterpilot
That sounds fine then! it will be a little thinner in consistency than a 50 weight, but it should shift very well!
Old Sep 7, 2011 | 08:39 PM
BeerKnurd's Avatar
BeerKnurd
Woohoo! Thank you and this awesome forum. Cheers!
Jermafenser
Oil & Lubrication
Dec 22, 2014 01:01 PM
super fly
Aug 16, 2013 08:46 AM
SilverSS
13
Jul 14, 2013 02:05 AM
farmnaggie
May 14, 2012 08:23 PM
tuckerjw
Jan 1, 2008 12:49 PM
