Okay... change of plans and with no real plans. Here is whats going on... Took the truck back to the shop because the diff. had swung up on me and threw the driveshaft all out of wack and started vibrating bad. I thought this was the fault of the guy that welded my spring perches onto the diff. Come to find out, when I lowered it a while ago, I took bad advise and removed the helper spring hoping to get more of a drop. This was more harm than good. Now when I accelerate the springs want to form a "S" and swings my diff up. I either have to replace with new springs, find and remount a helper spring, or..... i dunno. Not a welder so I'm kinda limited to what I can do. Any suggestions? I would love to do a Tri-4 link but then again... no welding. I have looked at Marz68's set up a few times and wouldnt mind something like that but I'm dealing with the stock frame and again.... no welding. Feel free to advise... thanks in advance.
The pinion is set at 4 degrees. Its a stock 360 with the stock original springs that had the helper taken out... which if I understand correctly, severely weakened the rest of the suspension under acceleration whether it be hard or easy. And I was looking into those over the top helpers and also the traction bars. I found a "bar" that has a mounting point under the spring perch where the u-bolts come through and connected to a heims joint and welded to the frame about 20 inches forward from the rear end. Anyone know about these?
Reason: i'm an idiot!
If it runs on an angle, say from right axle Ubolt to left spring perch, it is called a Panhard Bar. It is very common in High HP/TQ prostreet vehicles, and street strip vehicles.
Or are you talking about ladder bars? 1 on either side.
I really don't think these would be considered ladder bars but i don't know for sure. I know what a panhard bar is and this is not it. They run parallel with the frame and does not angle to the other side. I don't get on it hard enough to experience any wheel hop but I would assume it would being the amount of strain on the springs in the little bit of acceleration I put it through. The 4 degrees is angled up... and from what I understand is because the motor is angled down somewhat.... not sure what degree its angled down. I'm not sure but I think I'm leaning more towards getting the traction bars because I think they will go good with the look of the truck... kinda the old school look. But I will entertain any other suggestions at this point.
Thanks instig8r63. There isn't an application for my truck... they would probably build one for me but I'm sure that would be a pretty penny. And I have seen some of the costs for the others... not too sure I want to spend that kind of money considering that it will never see the track and I just need something for everyday use.
Okay, went with the traction bars from Lakewood and have already installed them. My issue is, the instructions suggest the snugger (rubber bump) should be about 1/2" from the leaf. It isn't... its about 4" and at this big of a difference I'm not sure if they will be doing any good. For my understanding, the snugger is supposed bump against the leaf to support the rear end from wrapping. And at a 4" difference, not seeing how thats going to happen. I'm sure the two u-bolts that attach the bar to the leaf with the rear end centered between them will prevent a little wrapping but not as much as it would with the aid of the snugger. Any suggestions?
4 inches means they wot work at all, get some pick and lets see what is wrong. maybe your spring arch is to great. Or you my need to make expander for the snubber's
This just popped into my head! I have had the rear jacked up since working on it with the rear end supported with the stands because I am redoing the brakes. Could this be why its off so much? I'm stuck at work until late evening and won't be able to check till I get home. I'm thinking since the front is angled down from the rear being up in the air... maybe, just maybe....? I don't under stand how these could be much different from an early muscle car leaf set up. You would think that the car would have a shorter distance leaf than a truck and those snubbers are really close to the leaf.
Wait a minute.... the snubbers don't come even close to the eyelet of the spring. I thought they were supposed to push up against the spring itself under load?
