another though about tranny coolers..
Old Aug 2, 2009 | 08:56 PM
caleb90's Avatar
caleb90
Temporarily Deactivated
i was brain storming again aboutsome things to do to my truck one of them beingtranny coolers..i no that the 6.0 coolerwould be the way to go but i cant find any at a resonable price.So i was wondering if you can take a cooler such as this one http://www.summitracing.com/parts/PRM-1014/ ..and insted of just puting one in put 2 of them in.run the "cold" line off the stock cooler to the "hot" side of the add on cooler,thenfrom the cold side on that same cooler to the "hot" side on the other cooler thenback to the tranny line? Can i do this with out having poblems?
Old Aug 3, 2009 | 06:14 PM
caleb90's Avatar
caleb90
so can you do this or will it cut down on fluid flow to much?
Old Aug 3, 2009 | 06:45 PM
superduty4x4's Avatar
superduty4x4
Why not just buy the TruCool Max 4739 and plumb it in series with your stocker? Then you have nearly the same cooling capacity as the 6.0 cooler. FWIW, the stacked plate coolers like the 6.0 cooler and your OEM one are more efficient than the tube and fin coolers like the one in your link.
Old Aug 3, 2009 | 06:53 PM
caleb90's Avatar
caleb90
the truecoolmax is sold out till some date in august..
Old Aug 3, 2009 | 06:55 PM
superduty4x4
Fubar... tis the season for lower trans temps I guess
Old Aug 3, 2009 | 06:57 PM
caleb90's Avatar
caleb90
well then how about this cooler...it looks like a stacked plate cooler..it has 46 rows in it...http://www.summitracing.com/parts/BMM-70274/
Old Aug 3, 2009 | 08:06 PM
superduty4x4
That one might do the trick.
Old Aug 3, 2009 | 08:25 PM
HKusp's Avatar
HKusp
You could get this one for less than $100 shipped to your door. If you are towing it will keep your temps down. I have it and it works great. Get the biggest one they sell.
http://www.autobarn.net/ultra-cool-t...l-coolers.html
Old Aug 3, 2009 | 09:14 PM
Headviking's Avatar
Headviking
all this talk about trans coolers. Isn't the stock trans cooler enough. Or is more better?
Old Aug 3, 2009 | 09:30 PM
Izzy351's Avatar
Izzy351
More is better. Mine used to get to 190ish in the summer running empty, even a little hotter if I'm hammering it. Now I can barely get it over 140 (I have the 26-row 6.0L cooler).
Old Aug 3, 2009 | 11:36 PM
superduty4x4
The stocker is WAY less than adequate. I don't think it could keep the trans in a Honda cool.
Old Aug 4, 2009 | 06:37 PM
msmith53's Avatar
msmith53
I got the same one (the biggest one) at my local NAPA store the other day for $73.00.
Old Aug 4, 2009 | 06:55 PM
Shake-N-Bake's Avatar
Shake-N-Bake
I completely agree.
Old Aug 5, 2009 | 12:19 AM
Headviking's Avatar
Headviking
I don't pull anything. Would my baby benefit from a larger oil cooler?
Old Aug 5, 2009 | 01:37 AM
kupaa's Avatar
kupaa
You have a 6.0 cooler and that is enough.
