Perfect balance
Old Aug 3, 2009 | 08:27 PM
  #31
fordrealdrive's Avatar
fordrealdrive
Originally Posted by ShamelessMT
Ok, I did some digging, and I'm still not 100% sure on this, but I'd say that most Fords had the wide ratio (w/ 6.69:1 1st). However, I've found multiple references to there also being a close ratio gearbox used by Ford. I know for a fact that both Dodge and Chevy used both close & wide ratio NP435's, but I can't find a solid source to verify or deny that Ford did also.
im not sure on this either but i think the close ratio 4spd's might have been used in the early 80's diesel trks?????
Old Aug 3, 2009 | 08:32 PM
  #32
ShamelessMT's Avatar
ShamelessMT
That would make a lot of sense, as diesels don't work real well with wide ratios. However, I did find an older thread on this forum that talked about them being in '70's trucks too and I've found it mentioned a few other times elsewhere. What we need is someone like NumberDummy to speak up about this if he can find the info.
Old Aug 3, 2009 | 08:36 PM
  #33
fordrealdrive
yes, this has my curiosity as well
Old Aug 3, 2009 | 08:58 PM
  #34
superd02's Avatar
superd02
ford had a close ratio from 64-87 with a ratio set of 4.78 1st, 2.39 2nd, 1.37 3rd, 1.00 4th
not sure on the reverse gear ratio sorry
i had this trans behind a 400 f350
