Interior Mock Up
Old Jul 29, 2009 | 09:06 PM
Holiver31's Avatar
Holiver31
Interior Mock Up
Finished painting. Here are a few pics-
Pics with seats to come soon. Any hints on getting this damned masking tape off?
Old Jul 29, 2009 | 09:36 PM
Bowtie_Schmowtie's Avatar
Bowtie_Schmowtie
I'm more interested in how you got it to stick in the first place. I can't get anything but duct tape to stick to mine. Rubbing alcohol on a cotton ball has worked well for me in the past, but I don't know what that would do to your fresh paint.
It's amazing what a difference carpet makes...I can't wait to get some in mine after I fix the floorboards and weatherstrip.
Old Jul 29, 2009 | 09:39 PM
Holiver31's Avatar
Holiver31
It stuck fine for me. To fine actually! I'll give the alcohol a try. My next idea was paint thinner, just have to be careful no to get it on the paint. The carpet gives it that new car smell! haha
Old Jul 29, 2009 | 09:56 PM
75F350's Avatar
75F350
Use better tape to prevent the adhesive from sticking. Blue and even green painters tape is best. It appears that you used too much tape and may should have used the tape to hold down any other material that did not stick.
There is one thing that WD-40 is good for, and that is adhesive removal. Try it. Works good on dead bugs and stuff like that too.
Old Jul 29, 2009 | 10:00 PM
Holiver31's Avatar
Holiver31
Sweet, just spray the tape down then peel?
Old Jul 29, 2009 | 10:13 PM
75F350's Avatar
75F350
Well, the tape is glossy on one side so it is difficult to penetrate. You will have to peel the tape as much as possible to expose the adhesive and then you will fin d the WD most effective.
A little heat from a heat gun is not a bad idea either. No heat gun, borrow the wife or girfirends hair dryer. Even on a low setting it is warm enough to make the adhesive pliable and easier to remove tape without tearing. Low heat will not harm your new finishes or dash pad, and then you can clean up the remaining adhesive with the WD.
Old Jul 29, 2009 | 10:21 PM
Holiver31's Avatar
Holiver31
Sounds like a plan,,don't need to worry about the dash pad though its already cracked.
Old Jul 29, 2009 | 10:29 PM
75F350's Avatar
75F350
Maybe taking that off would have been the ticket? Oh well, water under the bridge.
Looking real nice there.
Old Jul 29, 2009 | 10:31 PM
Holiver31's Avatar
Holiver31
The tape on the dash was easy to get off,,im not really concerned about it any. Its getting replaced. Like you said water under the bridge. Thanks for the compliment.
Old Jul 30, 2009 | 01:57 PM
Holiver31's Avatar
Holiver31
Meet Chaz, designated Co-Pilot
Old Jul 30, 2009 | 02:15 PM
jb10's Avatar
jb10
the seats look great! what are they out of?
good work
Old Jul 30, 2009 | 02:31 PM
Holiver31's Avatar
Holiver31
good work
2003 F150. Thanks.
Old Jul 30, 2009 | 03:43 PM
berry1234's Avatar
berry1234
Looks good. Those A/C vents could use a detail...
Old Jul 30, 2009 | 03:45 PM
Holiver31's Avatar
Holiver31
Thanks. Yeah, they are a wee bit on the dusty side.
Old Jul 30, 2009 | 03:48 PM
berry1234's Avatar
berry1234
Where did you get the carpet kit from and what was the cost if you don't mind?
